SEARCH'd already found NOTHING>>>wiring side markers
yeah so ive already used search and nothing came up..
so the question is, how do u wire up the side markers? i have a 1997 GS witht he side markers on already but not too sure about wires.
does anyone have a step by step i can look at?
thanks in advance
thanks in advance
Well, I have the same problem. I recently took them to a shop to have my front headlights re-wired.
I was told my sidemarkers were not even wired up at all, they were just sitting there, and that in order to wire them they'd have to be wired into the headlights. There is a problem with this though because, if it is not done correctly, it will cause hyperblink on your turn signals.
I'm not really sure how to avoid this but I'm having them do the sidemarks as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SYTFU Tommy. »</TD></TR><TR><TD CLASS="quote">just splice it with ur turn signals.</TD></TR></TABLE>
Yeah, thats what i'm saying.
Yeah thats what I was saying in my post. If it is spliced into the headlight incorrectly, I was told it would give you that hyperblink in your turn signals.
well my turnsignals already have hyper blink and i love it ;] i call it my racing blinker lights
but yeah, i herd about splicing the blinker lights but i wasnt sure how, i was wondering if anyone had a guide on this.
but if not,
thanks everyone for ur info.
i think one of my friends knows about wiring **** haha
but yeah, i herd about splicing the blinker lights but i wasnt sure how, i was wondering if anyone had a guide on this. but if not,
https://honda-tech.com/zerothread?id=1716378
Look how they do it there, it would be pretty much the same idea. You don't wire it to the blinkers but the parking lights or whatever they are called.
I have installed quite a few sidemarkers in my day and i hope my explanation can help
there is a 3-wire buld in your corner lense, you need to take it out, unplug the 3-wire bulb socket and run the wires from the sidemarker all the way to it
then there are 2 ways you can wire it, the OEM way (only turns on when you use the blinker) or the other way (turns on when you turn on your parking lights and blinks when you use the blinkers)
the best way to play around and see which one you like is to cut some of the cover off of each of the wires and attach the wires from the sidemarkers in different combonations to get your desired effect
I found this up top in the INTEGRA FAQ
http://www.integra.orcon.net.nz/indicator.htm
Here you go. This is what I used to do mine and they work PERFECTLY!
http://www.giuffre.com/persona...s.pdf
Good Luck
Good Luck
99siRACER
Dec 2, 2010 11:34 AM
