Repair or Scrap it???
Old Nov 14, 2006 | 05:11 PM
Blackjack3's Avatar
Default Repair or Scrap it???
So I might get a 94 ls for a smokin deal, free or cheap...It is in pretty good shape, with low miles. Anyway for the bad...It ran over a curb and some other crap i guess and now the wheels on the drivers side are alomost sideways It looks like it will need new rear control arms, coilovers, sway bar, I think thats about it for the rear, the sub frame looks to be intact, it might have a small crack. The front needs at least a coilover, probably an axle shaft, couldnt see much of the suspension because the tire was on. Ill try to get a closer look. Anyway I was thinking get coilovers all around, sway bar, and the other stuff replace with factory parts. So what would you do????
Old Nov 14, 2006 | 05:56 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: Repair or Scrap it??? (Blackjack3)
um .. for free, or Really cheap??
Take it before anyone else, that's what I would do,
even if you don't fix it, you could still part it out.
Old Nov 14, 2006 | 05:58 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: Repair or Scrap it??? (CleanLikeJdm)
just get it im sure it looks better than flatblacks^^^^^^^^^^^^teg anyday
Old Nov 14, 2006 | 05:59 PM
Blackjack3's Avatar
So I figured im getting this for so cheap, i may as well replace most of it with aftermarket parts. Here is my list, let me know if i missing anything...
-skunk2 coilovers
-skunk2/omni upper arms and lower
-rear lower arms (unsure of which ones to buy)
-ASR subframe brace w/ sway bar
Anything I should add?
Old Nov 14, 2006 | 08:17 PM
silverEG6's Avatar
dont forget to take it to a frame shop to make sure everything is aligned.
SoCal EJ1
Welding / Fabrication
20
Feb 28, 2009 01:01 PM
broketuner-Sol_Si
Suspension & Brakes
Apr 15, 2007 11:45 PM
italianchooch88
Feb 19, 2007 11:43 AM
excivicboy96
May 23, 2006 05:20 PM
