My Tranny is grinding
Old Nov 14, 2006 | 05:02 PM
crxowner's Avatar
Default My Tranny is grinding
When I drove my car one night it didnt want to go into 3rd and 4th too easy and grinded 4th Its a hydro LS btw. So I was like ok the synchros are going but on my way back home it shifted fine??? Now when im at wot its hard to get it into second and grinded once but if I take it up slowly It goes in easy and it grinded 3rd once at WOT then during regular driving it grindes 4th every once in a while.
It does not grind every time so i dont think its the synchros cuz it grinds any gear at random maybe its the clutch?
Old Nov 14, 2006 | 08:38 PM
Mario_D's Avatar
Default Re: My Tranny is grinding (crxowner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxowner &raquo;</TD></TR><TR><TD CLASS="quote">When I drove my car one night it didnt want to go into 3rd and 4th too easy and grinded 4th Its a hydro LS btw. So I was like ok the synchros are going but on my way back home it shifted fine??? Now when im at wot its hard to get it into second and grinded once but if I take it up slowly It goes in easy and it grinded 3rd once at WOT then during regular driving it grindes 4th every once in a while.
It does not grind every time so i dont think its the synchros cuz it grinds any gear at random maybe its the clutch?</TD></TR></TABLE>
It is probably the synchro and sleeve going south. certain combination of teeth sleeve combinations may net you a grind or no grind. When was the last time you checked your fluid?
m-
Old Nov 15, 2006 | 01:32 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: My Tranny is grinding (moops vs moors)
Replace your clutch before its too late.
Old Nov 15, 2006 | 11:17 AM
crxowner's Avatar
I changed my tranny fluid with honda MTF the next day(there were no metal shavings in it), I dont think sychromesh will help me now
And it only grinds while shifting, randomly
So... clutch or new tranny?
Modified by crxowner at 5:31 PM 11/15/2006
Old Nov 15, 2006 | 04:30 PM
crxowner's Avatar
nobody knows?
Old Nov 16, 2006 | 11:37 AM
crxowner's Avatar
anybody
Old Nov 16, 2006 | 02:59 PM
blinx9900's Avatar
Default Re: (crxowner)
im wondering this myself so i think here is a good place to ask... will the GM synchromesh fluid help any? i know the 88-91 lsd tranny guys love it.
Old Nov 16, 2006 | 03:45 PM
crxowner's Avatar
idk IM trading the car on sunday I just want to know so I can tell the guy whats wrong with it, I'm leaning more towards the clutch/pressure plate correct me if im wrong but the 2nd gear synchro has nothing to do with the 3rd gear synchro and theres no way one synchro will make 2nd 3rd and 4th grind once again it doesnt keep grinding the same gear it takes turns with 2nd 3rd and 4th
Old Nov 17, 2006 | 01:46 PM
NHswaps13203's Avatar
From: Swapin Motors,Tuckin Bays and Making Harness, CT, USfukenA
what kind of car is it in.....if its cable when my b16 clutch was goin it grinded changed it and it was fine....if it is hydro as in in a hydro car its the slave cylinder, pull the boot back and if it leaks fluid its shot
Old Nov 17, 2006 | 03:39 PM
crxowner's Avatar
Yea its a hydro and I plenty of fluid, it does have a small leak from the clutch cylinder(the one that bolts to the firewall) but I check my fluids often, I'm almost sure its my clutch so if this trade doesnt go through on sunday its getting replaced and I'll let you guys know the results for future references
Old Nov 17, 2006 | 04:10 PM
pull the boot back on the SLAVE cylinder if it leeks fluid thats your problem
Old Nov 18, 2006 | 02:34 PM
crxowner's Avatar
yup its the clutch when im rolling around 1-2mph and put the car in 1st it shakes slightly
JDM_EK4_Coupe
17
Apr 12, 2007 12:37 PM
HalfManHalfFred
Jan 14, 2005 07:51 PM
Kyles ej1
100
Aug 6, 2004 07:16 PM
roydogg
Dec 26, 2003 10:51 PM
AmauryR
Oct 10, 2003 11:45 AM
