check engine light on.
my buddies check engine light on his 90 civic si comes on after driving for abouit 2-4 minutes. but only at regular speeds 40-45 mph, not at slower speeds20-35 mph.
any suggestions or thoughts of why it comes on?
Check to see what the code is. how many blinks on the ecu. here is a link of the codes for you
https://honda-tech.com/zerothread?id=468260
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Creepshow STI »</TD></TR><TR><TD CLASS="quote">my buddies check engine light on his 90 civic si comes on after driving for abouit 2-4 minutes. but only at regular speeds 40-45 mph, not at slower speeds20-35 mph.
any suggestions or thoughts of why it comes on?</TD></TR></TABLE>
i bet o2. once the car is warmed closed loop is activated
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxben »</TD></TR><TR><TD CLASS="quote">Check to see what the code is. how many blinks on the ecu. here is a link of the codes for you
X2
</TD></TR></TABLE>X2
no to highjack this tread but my cars cel also lights on but every time i restart it ...its goes away...should i bother pull out my ecu will it still have the information even if i shut the car off??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RockWolf »</TD></TR><TR><TD CLASS="quote">no to highjack this tread but my cars cel also lights on but every time i restart it ...its goes away...should i bother pull out my ecu will it still have the information even if i shut the car off??</TD></TR></TABLE>
Yeah check it for codes,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ »</TD></TR><TR><TD CLASS="quote">you dont pull out the ECU to check codes...
pull back the carpet and count how many times the red dot blinks. </TD></TR></TABLE>
hehehehe
hehehehe
make sure there is not a pause, the ecu will blink more than one code at a time if needed
blink, blink, blink....pause....blink, blink, blink, blink....long-pause....
would be codes 3 & 4 the blink pattern starts over at the long pause
prwittman
Jul 13, 2018 01:00 PM
GreenMachineRex
May 27, 2004 06:11 PM
