turbo d bogs out.. help
Old Nov 14, 2006 | 02:53 PM
bmw626's Avatar
Default turbo d bogs out.. help
whenever i go 3/4 - WOT throttle, my turbo will start to make boost and around 4-5k it will just bog out and die unless i push the clutch in. my inital thoughts are fuel filter and/ or spark plug gap. i am gonna change the filter tomorrow and my plugs are gapped at .39 and are two steps colder than stock. (NGK) i am running a crome basemap @ 5.5 psi. it didn't start doing this till two weeks after being boosted. any other ideas other than what i have listed? i plan on going to get her tuned next month
Old Nov 14, 2006 | 02:57 PM
EJ1 wilcox's Avatar
Default Re: turbo d bogs out.. help (bmw626)
The obvious answer would be to get tuned.
Old Nov 14, 2006 | 04:21 PM
CRXdan's Avatar
how bad does it bog? so bad that you cant rev to 7000rpm? I remeber disconnecting the IACV or somethign liek that caused my car to do that.
Old Nov 14, 2006 | 04:22 PM
coneheadsracing's Avatar
Default Re: turbo d bogs out.. help (EJ1 wilcox)
Boosting on a basemap with wideband = ok
Boosting on a basemap, without =
Do you have a wideband? It could be lots of things. If you were a tad lean for the last couple of weeks, now you could be really hurting. Any more info?
Old Nov 14, 2006 | 04:30 PM
bmw626's Avatar
Default Re: turbo d bogs out.. help (coneheadsracing)
the blokes that did my motor work said as long as i had a built motor i could run a basemap without damage. I dont have a wideband. I will slowly rev upto about 3500 and try to take off and its like the car is trying to cut out and die, and if i let off and try to accelerate again it wont work, the only way to get it to resume is to just upshift. how much does it cost to have someone do a tune?
Old Nov 14, 2006 | 04:34 PM
93turbo16's Avatar
Gap your plugs down to 28 and it will fix it.
Old Nov 14, 2006 | 04:35 PM
bmw626's Avatar
Default Re: (93turbo16)
what about the tune? how much will that cost?
Old Nov 14, 2006 | 04:37 PM
93turbo16's Avatar
Default Re: (bmw626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmw626 &raquo;</TD></TR><TR><TD CLASS="quote">what about the tune? how much will that cost?</TD></TR></TABLE>
Gap the plugs down and it will get you by for now. Definitley get it tuned asap.. call shops around you and see if someone can do it. Or contact J-Davis on here, he tunes in NC.
Old Nov 15, 2006 | 06:26 AM
redzcstandardhatch's Avatar
something different
they told you you'd be ok with a basemap with a built motor? idiots.
i wouldnt spend hard-earned money there again
Old Nov 15, 2006 | 06:29 AM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmw626 &raquo;</TD></TR><TR><TD CLASS="quote">the blokes that did my motor work said as long as i had a built motor i could run a basemap without damage. </TD></TR></TABLE>
I wouldn't go back to the blokes
Old Nov 17, 2006 | 07:11 PM
oscarmayer's Avatar
you need to find a decent tuning shop and get the car tunes. they coudl have never been more wrong. you can melt a motor down built or not if it's not tuned. and with FI it's faster to melt it down.
Old Nov 17, 2006 | 08:10 PM
something different
Default Re: (oscarmayer)
exactly.
totsie7944
Dec 8, 2006 10:10 AM
flatblackintegragsr
Apr 1, 2006 10:53 AM
Project_Civic
Apr 3, 2005 05:07 PM
digkhangboyz
Dec 28, 2004 08:44 AM
