OIL Pressure Gauge
Old Nov 14, 2006 | 02:53 PM
sasinorm01's Avatar
Default OIL Pressure Gauge
just installed the autometer pro comp elelctrical oil temp gauge and the gauge needle isnt moving...is there a special wire needed for the sender to the gauge?
Old Nov 14, 2006 | 04:02 PM
Mr_CRX's Avatar
Default Re: OIL Pressure Gauge (sasinorm01)
There should be a wire from the sender to the gauge. The sender also needs to be grounded.
Old Nov 14, 2006 | 07:08 PM
sasinorm01's Avatar
ground the sender?...how and where?
Old Nov 14, 2006 | 07:41 PM
shortyz21's Avatar
Default Re: (sasinorm01)
where did u mount the sender?
Old Nov 14, 2006 | 10:50 PM
Mr_CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sasinorm01 &raquo;</TD></TR><TR><TD CLASS="quote">ground the sender?...how and where?</TD></TR></TABLE>
Either with a bracket holding it to the firewall, or sometimes it can get grounded through the stainless braided line to the engine block.
You did hook up the other wires on the gauge, right?
Old Nov 15, 2006 | 05:19 PM
sasinorm01's Avatar
i have it attached to an adapter thats attached under the oil filter...and all the wires are connected
Old Nov 15, 2006 | 06:44 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sasinorm01 &raquo;</TD></TR><TR><TD CLASS="quote">i have it attached to an adapter thats attached under the oil filter...and all the wires are connected</TD></TR></TABLE>
Have fun when the sender snaps off the block and your engine's oil empties onto the road.
https://honda-tech.com/zerothread?id=1138497
Old Nov 15, 2006 | 06:49 PM
sasinorm01's Avatar
so i guess u dont have an oil pressure gauge then
Old Nov 15, 2006 | 06:52 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sasinorm01 &raquo;</TD></TR><TR><TD CLASS="quote">so i guess u dont have an oil pressure gauge then</TD></TR></TABLE>
No, but if I did, i'd do it like the link I posted.
xx89civicracer89xx
May 17, 2006 07:20 PM
Turbo_TONY
Mar 8, 2006 07:46 PM
Si Shane
Oct 20, 2005 02:47 PM
96gsrvtec1986
Mar 17, 2005 06:36 AM
AutoXsi2000
Jul 27, 2002 06:04 PM
