~~~Project0 EJ1~~MUNKY W3RKZ INC.~~~
Old Nov 14, 2006 | 02:47 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default ~~~Project0 EJ1~~MUNKY W3RKZ INC.~~~
always updated on first and current last pages.....
<U>UPDATE PG 25,27</U>
FIRST AND FORMOST....
bisimoto.com rules
well as some my know the last month has been a pretty bad month for me and the the coupe..
4 weeks ago the built Z6 went down...
replaced it with a temp JDM D15B with 20K on it with the new Turbo set up
shortly after a oppsy happened and my front end was damaged...
i had plans for full paint after i pulled my 11sec SOHC pass, but now is the time to make the full changes i had planned for...
well here are some current pics of the car after dropping it off for paint...
more to come as the time goes by....
enjoy
pics of the car before
then the opsy happened
so i begin the rebuild!!!
car is due back in about 2 weeks.. i will update the paint and body as days go one.. then continue with the bay etc...
a Vac box im making for it...
Update...
15nov06
vac box finished being made and powdercoated...
updates
16nov06
body work done.... start prep for primer......
repaired CF hood
got my SS tubing for the brake lines.. tomorrow ill get the fittings .....
UPDATE
18Nov06
Pistons came in
UPDATES..
20NOV06
body sanded and ready for Primer.... tomorrow or weds
UPDATES
27NOV06
car is primed.... wet sanding is goign on today and tomorrow... paint ordered and shooting will take place wed/thurs
my "randy" sticker got pulled off with the tape...
ok guys.. just went by to see the paint.... just got out the booth.. so itsstill fresh.. its dark and lighting is throwing it off...
and no it isnt WHITE....
update
29NOV06
with flash
no flash
no flash
flash
Originally Posted by Jun805
so how is it? does it look crazy in the sun? my bro called me when u guys were on yer way back to yer pad... or ?
its funny the paint is tripy..... with light hitting it it appears to be white and then fades away to the greyish blue green color... still needs to be cut and buff and detailing on some of the overspray.....
UPDATE
01DEC06
here is a example.. the garage light is on and you can see how it looks white in the rear and fades away to the actual color of the car....
here is it with the garage light off.. see the diff....?
i started installing the tail lights and seals but light is running out and im tired and sick..... i will be installing everything else then pulling the motor out this weeken di hope...
and my fittings came in today
UPDATES
02DEC06
ok well i spent the day working on the coupe....
as you may know this was a EX-S( ABS EX ) meaning it had the works.... so i had to clear out the bay this is what i had to start with
pulled out the JDM D15B
here is what was left to clear out in the bay... all the MISC brake lines for the ABS/ harness etc
Adios ABS
some of the many things i took out
this is what im left with as of right now till i finish clearing out more...
and BTW... my wheels came today!
white TE37's FTW
and this is where i got the color from
ok today i got a lil early from work and put some elbow grease in the bay
UPDATE....
04DEC06
got my EK side skirts
and scuffed up the bay with 100 grit to get the rough build up off
Modified by S@nt0s at 10:12 PM 12/2/2006
UPDATE
05DEC06
pulled the dash out.. thinking if i will remove the heatercore or not.....
who the ***** needs SRS....
updates
10DEC06
went thru the bay today and cleaned up some stuff and layed the first coat of primer
and my headlights and corners came in... y3y y3y
UPDATES....
12DEC06
came home from work to find these bad boys....
15x7 +40
here is some progress from today.... started filling a lil , welded a lil... smoothing a lil out...
UPDATE
16DEC06
UPDATE
07JAN07
ok guys today o went at it for a few hours and threw 2 coats of paint... another 2 more later this week plus went sanding......
update... plate came in
07FEB07
UPDATE
12FEB07
well since i am now on vacation ( which im taking to finish the car) i resprayed teh engine bay and cleared it.. i still need to wet sand it.....
i will wrap up the brake lines this week and try to drop the motor in this weekend...
Modified by S@nt0s at 6:11 PM 2/27/2007
Old Nov 14, 2006 | 02:50 PM
Yellowone's Avatar
Default Re: ~~~Project0 EJ1~~MUNKY W3RKZ INC.~~~ (S@nt0s)
My favorite coupe
Old Nov 14, 2006 | 02:58 PM
Viorent Grip! EG's Avatar
Default Re: ~~~Project0 EJ1~~MUNKY W3RKZ INC.~~~ (Yellowone)
for updates
what times u pull at the track?
Old Nov 14, 2006 | 02:59 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: ~~~Project0 EJ1~~MUNKY W3RKZ INC.~~~ (Viorent Grip! EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Viorent Grip! EG &raquo;</TD></TR><TR><TD CLASS="quote"> for updates
what times u pull at the track?</TD></TR></TABLE>
on the built Z6 with the greddy kit on a map not tuned for the cam it pulled 8.6 at Irwindale..
this is a full weight EX w/ abs and all...
2" Downpipe and stock cat w/ exhaust also were still on the car during those runs
Old Nov 14, 2006 | 03:00 PM
ATS*Mark's Avatar
OG triple OG
bought not built , then rebuilds it crew fellow member lol
i know the outcome will be sick foo!!!
Old Nov 14, 2006 | 03:02 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: ~~~Project0 EJ1~~MUNKY W3RKZ INC.~~~ (ATS*Mark)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATS*Mark &raquo;</TD></TR><TR><TD CLASS="quote">bought not built , then rebuilds it crew fellow member lol
i know the outcome will be sick foo!!!</TD></TR></TABLE>
HAHAHAH u funny jokies
Old Nov 14, 2006 | 03:03 PM
SleeperDC2_ZzZ's Avatar
is that a sohc sticker vtec sticker?
Old Nov 14, 2006 | 03:06 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: ~~~Project0 EJ1~~MUNKY W3RKZ INC.~~~ (SleeperDC2_ZzZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeperDC2_ZzZ &raquo;</TD></TR><TR><TD CLASS="quote">is that a sohc sticker vtec sticker?</TD></TR></TABLE>
i think someone just got OWNED!
Bite your tongue before you call me a poser... i have plently of builds under my belt no need to fake the funk
Old Nov 14, 2006 | 03:07 PM
ATS*Mark's Avatar
OG triple OG
sohc
Old Nov 14, 2006 | 03:08 PM
sh!tsWEAK!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATS*Mark &raquo;</TD></TR><TR><TD CLASS="quote">sohc </TD></TR></TABLE>
Old Nov 14, 2006 | 03:09 PM
ATS*Mark's Avatar
OG triple OG
Default Re: ~~~Project0 EJ1~~MUNKY W3RKZ INC.~~~ (sh!tsWEAK!)
good dammit i dont want people to see that !!!!
Old Nov 14, 2006 | 03:11 PM
turbotime's Avatar
to my ej1 rebuildin brother! Your goin topmount too lol!
Old Nov 14, 2006 | 03:13 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote"> to my ej1 rebuildin brother! Your goin topmount too lol!</TD></TR></TABLE>
already was.... but i will be redoing teh set up again when i rebuild teh Z6 this month... then do the entire bay after the car comes back
Old Nov 14, 2006 | 03:19 PM
eJone powereD's Avatar
Default Re: (S@nt0s)
cant wait to see it pinished pool...what color you going with and how much is he charging you?
Old Nov 14, 2006 | 03:20 PM
XxSOHCDriVerxX's Avatar
*****h thats my sticker....LOL....good luck on my old coupe. you gotta treat her better man..crashing and ****.. =P
Old Nov 14, 2006 | 03:21 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (eJone powereD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eJone powereD &raquo;</TD></TR><TR><TD CLASS="quote">cant wait to see it pinished pool...what color you going with and how much is he charging you?</TD></TR></TABLE>
the color is a hush huhs.. and it isnt RED...
Old Nov 14, 2006 | 03:24 PM
sh!tsWEAK!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATS*Mark &raquo;</TD></TR><TR><TD CLASS="quote">good dammit i dont want people to see that !!!! </TD></TR></TABLE>
Sig worthy? I think so!
Old Nov 14, 2006 | 03:59 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: ~~~Project0 EJ1~~MUNKY W3RKZ INC.~~~ (ek four)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek four &raquo;</TD></TR><TR><TD CLASS="quote">paint it pink you girl</TD></TR></TABLE>
imma paint it purple like someone i know!
Old Nov 14, 2006 | 04:15 PM
Autoworks's Avatar
hot coupe, I'll have to keep pan eye on this one...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">
sig worthy
Old Nov 14, 2006 | 04:19 PM
ITRbroham's Avatar
shit post warrior
Bite your tongue before you call me a poser... i have plently of builds under my belt no need to fake the funk</TD></TR></TABLE>
ROFLMAO!
Jeez........somebody could possibly use a coochie blower today!
Good luck w/ the repairs.
Old Nov 14, 2006 | 04:20 PM
Built to Spill's Avatar
el diablo
beautiful car (before)
keep us updated on the after
Old Nov 14, 2006 | 04:42 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: ~~~Project0 EJ1~~MUNKY W3RKZ INC.~~~ (ITRbroham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRbroham &raquo;</TD></TR><TR><TD CLASS="quote">
ROFLMAO!
Good luck w/ the repairs. </TD></TR></TABLE>
just telling it like it is home slice.. u knwo how the 310 does it!
Old Nov 14, 2006 | 04:48 PM
ATS*Mark's Avatar
OG triple OG
nice wanna be race stickers on the side
Old Nov 14, 2006 | 04:49 PM
ZacCarter's Avatar
DO IT!!
Old Nov 14, 2006 | 04:54 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATS*Mark &raquo;</TD></TR><TR><TD CLASS="quote">nice wanna be race stickers on the side </TD></TR></TABLE>
look whos talkin Mrs. i have spoon stickers in my door
