95 GSR Hard Gettin into to Gear at High RPM
Old Nov 14, 2006 | 12:06 PM
TruGsr1's Avatar
Default 95 GSR Hard Gettin into to Gear at High RPM
I Recentely bought a 95 GSR 84, XXX miles on it. I've noticed once the car goes above about 6,000 RPM it get really hard to get it into gear like something is in the way of the shift linkage. I really notice it more often going into 2nd gear from 1st and sometimes from 2nd gear to 3rd. I was wondering if anyone has had similar problems or kno what may be wrong. I'd reallly aprreciate some help because its startin got get annoying and is making me miss 2nd gear when I race.
Old Nov 14, 2006 | 12:23 PM
skunked's Avatar
Default Re: 95 GSR Hard Gettin into to Gear at High RPM (TruGsr1)
synchro's or clutch.
You can try to change the fluid to see if that helps as well.
Old Nov 14, 2006 | 03:28 PM
TruGsr1's Avatar
Default Re: 95 GSR Hard Gettin into to Gear at High RPM (skunked)
Thanks How much does it typicallly cost to replace synchros?
Old Nov 14, 2006 | 03:35 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TruGsr1 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks How much does it typicallly cost to replace synchros? </TD></TR></TABLE>
Depends if you pull the tranny and drop it off for a rebuild or have a tranny shop do the whole job.
Mcdc2
Jan 12, 2008 10:49 PM
crackegg
Sep 18, 2005 10:48 AM
L8ApexH22
Oct 29, 2004 08:35 PM
gsrteg93
Apr 30, 2003 11:07 AM
