quick question: when changing front calipers, is it necessary to bleed the rears?
Well i'm hitting up the drag strip soon and i'm switching my front brakes from wilwood to stock so I can run 13's, and I was simply wondering would I need to bleed the rears as well?
Thanks in advance!
Thanks in advance!
You shouldn't have to if you clamp the line off before you change the caliper to avoid excessive fluid loss
