SERIOUS help needed ASAP!!!
I just put in two brand new front axles, replaced every ball joint in the front end, and put in brand new tie rods. I then got a front end alignment, and the next day, i start hearing a soft sound, like the beating of a helicopter's blades, and it gets continually louder until it feels and sounds like i've got a flt tire, but all the tires are 100% fine. It makes the noise whether the clutch is in or the accelerator is pushed, and it got continually worse.
I have no idea what could be wrong! EVERYTHING in the front end is new, and now it's making wierd noises! HELP!
jack the car up and spin the wheels to see where the sound is coming from. Sounds like an axle issue.........
your not leaking fluid right?
Make sure your dust shields aren't rubbing the rotor too.
Modified by skunked at 1:07 PM 11/14/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">I had to remove the rotors to reduce weight to to ease the fitment of new ball joints. Maybe that's it? I'll jack it up tonight and check for leaks and such. </TD></TR></TABLE>
Modified by nafreak at 5:37 PM 11/14/2006
Vagitarian
12
Jul 10, 2012 02:35 PM
93FastLs
Nov 3, 2005 11:29 PM
Spn_BB2
Dec 20, 2004 07:00 AM
THALADOR
Nov 6, 2004 08:31 PM
