Suspension & Brakes Theory, alignment, spring rates....
Ground Control
Old Nov 14, 2006 | 09:46 AM
koulaid's Avatar
Default Ground Control
are ground control coilovers for a 92 hatch with stock shocks good? Smooth?
Old Nov 14, 2006 | 09:54 AM
dvp's Avatar
dvp
Default Re: Ground Control (koulaid)
"Good"...no. Smooth...that's dependent of opinion and the shocks you use. Using the stock shocks will give you a shitty ride and you wont be able to lower the car the way it's supposed to be. Even if you order the off the shelf Ground Control spring rates those shocks are going to be working hard to try to control the springs = a bad ride and even worse performance.
Old Nov 14, 2006 | 10:50 AM
Tyson's Avatar
no.
Old Nov 14, 2006 | 11:09 AM
koulaid's Avatar
Default Re: Ground Control (dvp)
its its not, then what coilover system is good for cheap? under $500
Old Nov 14, 2006 | 11:14 AM
Tyson's Avatar
why do you need adjustable springs?
tokico illuminas and a good set of drop springs like eibach pro kits will cost about $500 and ride excellent. "nice and smooth"
Old Nov 14, 2006 | 11:24 AM
ED3_FTW's Avatar
wouldn't recommend on stock shocks, especially if your in a "slammin'" frame of mind
Old Nov 18, 2006 | 06:10 AM
koulaid's Avatar
Default Re: Ground Control (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">why do you need adjustable springs?
tokico illuminas and a good set of drop springs like eibach pro kits will cost about $500 and ride excellent. "nice and smooth" </TD></TR></TABLE>
o yea. kool . ill search around and see how it is. thkx
all-mtr-teg
Suspension & Brakes
Mar 5, 2007 02:42 PM
threesixes
Suspension & Brakes
Feb 5, 2007 10:13 AM
MadWackOops
Nov 9, 2003 09:28 PM
arete213
Oct 3, 2001 03:39 AM
