please help possible blown ecu or main relay
ok ima dumbass but heres wut happened my car is a 88 civic lx with a d15b2 and when it gets real cold the car has problems it doesn't want to stay started you have to hold the peddle till it starts to warm up then its good but more recently i found that the guy i bought the car from wus equally if not more of a dumbass because he fuked with the main harness and the wire to the i think its the fuel air control or sumthin but the plug part is gone and the wires are rigged (two little wires) and i found movin them around could get the car to stay started so i was in the process of this when my dumb lazy *** tried to use a screwdriver to push them in for better connection when the driver slipped and hit the intake manifold shorting something out and killing the car instantly now it turns over but doesn't start im currently gettin a new main relay just in case but its on order anyone know any other problems i may have caused?
91ef-si
May 4, 2019 09:15 AM
poundedhatchcrap
19
Jun 22, 2005 05:53 PM
oldbeefcake
11
May 2, 2004 06:26 PM
