Aftermarket door lock actuators?
Old Nov 14, 2006 | 07:56 AM
kkesler's Avatar
Default Aftermarket door lock actuators?
Need to replace a couple of actuators in my wife's Accord, and I was curious if anyone had gone to aftermarket units instead of OEM.
Also, if not then where is a good source for the OEM units aside from a dealer?
Modified by kkesler at 2:03 PM 11/14/2006
Old Nov 14, 2006 | 10:12 AM
hondadude's Avatar
Default Re: Aftermarket door lock actuators? (kkesler)
Hmmm???
Old Nov 14, 2006 | 10:29 AM
kkesler's Avatar
Default Re: Aftermarket door lock actuators? (hondadude)
99 Accord 4 door.
Old Nov 14, 2006 | 11:09 AM
pd0019's Avatar
i went aftermarket on my actuators for my 94 accord. i have been somewhat happy with then. about a year after the install...the connector holding the new actuator pole to the lever that lifts and lowers the lock broke. simple fix, all i needed was a little duct tape to tie the two poles together. thats my only grief
Old Nov 18, 2006 | 04:14 PM
kkesler's Avatar
Default Re: Aftermarket door lock actuators? (pd0019)
Ok, did one door today and this was too easy. Used a cheapie generic two wire polarity reversing actuator and wired it straight to the wiring that went to the factory actuator (one white and one green wire on one of the two plugs going to the factory actuator). Screwed it in, bent the rod to fit and connected it. Anyway, thought I would add my experience so others would find it in a search. Maybe 25 bucks and 1/2 hour.
Old Nov 20, 2006 | 09:57 AM
kkesler's Avatar
Well, now it appears that this effects the built in alarm. Anyone have the directions for the factory alarm system?
Neteiru
Jul 25, 2017 09:32 PM
southeastbeast
Oct 25, 2007 11:19 AM
poly35
Sep 22, 2004 09:08 AM
dbraunsdorf
Sep 1, 2004 08:19 PM
