engine / exhaust rumble
I searched already;
make: Honda Accord 2000 SE, AT
If exhaust valves too tight, will that make engine/exhaust to rumble ?
as rpm go higher rumbles get louder.
is it OK to run like this ?
my valve doesn't make any ticking noise, do I still adjust them anyway ?
Thanks in advance.
Thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ujhonda »</TD></TR><TR><TD CLASS="quote">Am I having A-pipe buzzing noise ?
I don't know if 6th gen cars have A-pipe issue
please give me some info.</TD></TR></TABLE>A-pipe buzzing sound more like, well, buzzing. Rumbling sounds like your muffler is going bad. It's hard to tell without listening first-hand.
Hi JimBlake:
It's not my muffler, sound coming from engine bay near manifold and kind of behind intake TB
and
my valves not ticking at all, so I am thinking - is my valve lash too close ?
Thanks for the reply.
edit:
my cylinder Head being shaved and installed by local shop while they at Head Gasket - after that all these, shsh started.
and
edit:
How about a leak in that flex-bellows section of the exhaust pipe. That's sorta in that general area.
Mostly I was just thinking you wouldn't call it a 'rumble' if it was a buzzing noise. Sometimes you just have to hear it firsthand...
rumble your talking about is what i got. Its a small exhaust manifold leak near the bottom of the pipe. To me it sounds like a baby harly when i coast at idle and burly press the throttle. Its not loud at all but its there.
only can hear it between 800 and 1.8k rpms
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadow_ridge »</TD></TR><TR><TD CLASS="quote">rumble your talking about is what i got. Its a small exhaust manifold leak near the bottom of the pipe. To me it sounds like a baby harly when i coast at idle and burly press the throttle. Its not loud at all but its there.
shadow_ridge:
yes, thats exactly what I am having, but mine can hear between 2k rpms and up all the way.
let me see I will pull the exhaust manifold - heat shield off tomorrow.
Thanks for all the help guys.
shadow_ridge:
hungtat
Apr 27, 2006 03:57 AM
