CAROLINAS: FS or Trade EBP EK rolling chassis.
98 Honda civic SI hatchback rolling chassis.
Trying to find a 98 or better IS300 or GS300 in ok condition.
engine is out of it but i have an ITR bottom end, full LS bottom end and a p30 head with 99+ cams, dual valve springs and ti retainers. head is getting a port/polished and 3 angle valve job as we speak!
selling the chassis for $4000 w/o motor or considering trades
More pics on it's transformation from the lonely lil Hatch I found at Import Auto Salvage.https://honda-tech.com/zero...age=1
here's the info
CHASSIS:
98 CIVIC DX HATCH. Stripped of beseries swap, fenders, rear wing..and main harness clipped by theives
SKUNK2 COILOVERS
SKUNK2 EXTENDED WHEEL STUDS w LIGHT LUGS (front only)
99 CIVIC SI OEM FRONT STRUT BRACE
99 CIVIC SI OEM FRONT CTRL ARMS. for use with a sway bar soon.
99 CIVIC CX AC BLOCK OFF
TENZO REAR STRUT BRACE. Polished
INTEGRA GSR RADIATOR. full length, lower brackets re-welded on rad support**
** hole cut like coupe prior to paint for cold air
** rear quater panels/wheel wells cut to prevent wheels from scrubbing
** holes made for OEM sturt tower brace like SI
** All sound deadening removed and repainted
** all ac lines removed.
WIRING, HARNESSES, AND ETC.
99 CIVIC SI MAIN ENGINE HARNESS. So that it was all plug and play
99 CIVIC SI MAIN DASH HARNESS. So that it was all plug and play
99 CIVIC SI MAIN FLOOR HARNESS. had to adapt to hatch rear plug (male vs. female
99 CIVIC DX ECU. Used to make jumper. plug cut soildered/heat shrunk
93 EX MAIN CAR HARNESS CLIPPING.Used to make jumper.
ENGINE
92 JDM SIR B16A swap complete from http://www.importautodsalvage.com
b18a block bored to 81.5mm and decked
b18b crank and rods
81.5 ITR pistons/rings (made by a company called TopLine that makes exact replica pistons, coated, webbed and marked p73...the whole 9 yards so...shhh)
92 JDM SIR2 head, manifold, and cams
STR adjustable cam gears
stock SIR valves
dual valve springs (SIR intake side, ITR exhaust side)
Ti retainers of some brand.
OEM Honda b18b head gasket.
HEAD was cleaned,valves reseated, and machined
99 CIVIC SI DISTRIBUTOR. To prevent having to cut and splice
99 CIVIC SI INJECTORS. To prevent having to cut and splice
99 CIVIC SI STARTER. To prevent having to cut and splice
99 CIVIC SI ALTERNATOR. To prevent having to cut and splice
**ALL BRAND NEW SEALS from top to bottom
MUGEN OIL CAP. Real I have the box from when I bought it
AEM COLD AIR INTAKE
OEM GSR HEADER
OEM SI CAT. Functioning but not currently one car
CUSTOM TEST PIPE w 02 BUNG
99 CIVIC SI OEM EXHAUST w GSR REAR MUFFLER. Till I get an APEXi N1
TRANS, AND ETC.
JDM SIR2 (non LSD) with oem flywheel and DUAL friction clutch.
STOCK AXLES
STOCK LINKAGE
TENZO SHORT SHIFT
INTERIOR
99 CIVIC SI DASH CONVERSION. Dash, heater core, inlet pipe/valve, blower motor, heater/ac main harness, heater controls, dash bezel( all from a 99 SI)
99 CIVIC SI CLUSTER. switched speedo from DX cluster for acurate mileage
99 CIVIC SI CD PLAYER
99 CIVIC SI STEERING BOSS. Leather wheel part around airbag
99 CIVIC SI SHIFT **** AND SHIFT BOOT
99 CIVIC SI CENTER CONSOLE w ARMREST
99 CIVIC SI FOG LIGHT, MIRROR, AND SUNROOF SWTICHES
99 CIVIC SI FLOOR MATS
SPARCO SPEED SEATSw SPARCO rails. Slightly faded near windows from the SUN, but red w black anti abrasion pads.
SPARCO CLUBMAN 3PT HARNESSES. Red, Brand new.
99 INTEGRA LS REAR UPPER SEATS. 98 Civic DX lower. planned to recover with LS lower seat material
EXTERIOR
99 CIVIC FRONT BUMPER
99 CIVIC FENDERS
99 CIVIC VIS CF HOOD. quater size chip in clear from rock
99 CIVIC OEM headlights (painted flat black)
99 CIVIC OEM FOG LIGHTS
99 CIVIC CTR FRONT GRILL
99 CIVIC CTR FRONT LIP
99 CIVIC CTR REAR LIP
SPOON STLYE MIRRORS. Non-power
99 CIVIC ELECTRON BLUE PEARL PAINT. B95P
SHAVED DOOR HANDLES. Since the car had been stolen before thur the door
SHAVED ANTENNA
SHAVED REAR EMBLEM
99 CIVIC SI OEM EMBLEMS AND DECALS. 2 dohc vtec, SI and CIVIC
CF REAR DUCKBILL
99 CIVIC 3DR TAILIGHTS
S2000 OEM HONDA SIDEMARKERS. sockets also
WHEELS
17x 7.5" RH Evolution CP-10's. Bronze, about 1000 miles on them
205/40/17 VISA tires. made by Falken, looks like kumho 712's
****The car also recently got GSR brakes in the front and a MSD M6AL igniton setup!
<FONT SIZE="2"><FONT COLOR="blue"> $10,000 OBO</FONT></FONT>
Just enough to fund My coupe project, if someone where serious enough to buy it. Maybe I will put it on EBAY. LOWBALLERS AND NEGATIVITY WILL ONLY WASTE SPACE!
** keep in mind this car is a SALVAGE and it was salvaged only because the motor was stolen(it was a B series engine, the pass tranny front was still in the car!). IMPORT AUTO SALVAGE in Marion, NC can back all the info up. I can Help get another copy of the title and we will take the price out of the purchase price.
here's the info
CHASSIS:
SKUNK2 COILOVERS
ENGINE
b18b crank and rods
stock SIR valves
AEM COLD AIR INTAKE
OEM GSR HEADER
TRANS, AND ETC.
STOCK AXLES
STOCK LINKAGE
TENZO SHORT SHIFT
INTERIOR
EXTERIOR
99 CIVIC FENDERS
SHAVED ANTENNA
SHAVED REAR EMBLEM
CF REAR DUCKBILL
WHEELS
civicdust
Jan 27, 2006 03:58 PM
ToyoSupraRZ
May 3, 2005 07:32 PM
