Do I need to replace oil pump for NA build?
I've got a 1993 H22 JDM Lude with 60k miles on the clock, and am getting it built NA soon with cams, pistons, P&P, Hondata etc, etc. I'll be replacing the water pump when the work's carried out, but do I also need to replace the oil pump? If so, should I just use an OEM pump?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest »</TD></TR><TR><TD CLASS="quote">+1 for OEM.
I'm still not convinced about the Prodrive oil pump gears either. </TD></TR></TABLE>
its a complete waste of money man, when i took my last pump out, and measured it for clearances, they lobes on the gear itself had too much clearance, and even sizes around the whole gear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude »</TD></TR><TR><TD CLASS="quote">
its a complete waste of money man, when i took my last pump out, and measured it for clearances, they lobes on the gear itself had too much clearance, and even sizes around the whole gear.</TD></TR></TABLE>
so youre saying that the prodrive gear wears out more than the stock one? or just that its no better?
quality is not worth the money, and they're customer service sucks, i had one of there gears go out on me, and they were jus giving me the runaround. screw them.
your best bet would be just to get a new oem one
Ek00fbp
Dec 25, 2003 04:54 PM
