GSR HEAD on B16 BLOCK?
alright.. so i searched... and i came up with only the opposite combo (b16 head on gsr block) soo here it is... im looking at a 95 integra with 00 front end.. its orginally a gsr but i guess he blew the block... but anyways he replaced it with a b16 block and it has the original head/tranny... so would this set up be slower than a stock gsr/si motor w/ same mods (i/h/e)? any input would be great... thanksss
p.s. sorry if its been covered.. point me in the right direction cause i can't find it
tony
tony
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97itypeR »</TD></TR><TR><TD CLASS="quote">wouldnt it be slower because the b16 block cant rev as high as a GSR?</TD></TR></TABLE>
Nope, if anything the B16 can take a little more revving than the GSR. Both have the same redline.
The car is definitely going to be slower than a stock GSR because there's less torque and the tranny isn't geared for the torque deficiency.
the car is from my brothers girlfriends little brother.. soo i know what its been through... he works at a lexus dealer and knows alot about hondas... the reason he did it is cause he needed a running car and just threw something together...but would this be slower than a regular si motor? bump for any info
tony
tony
It'd be about the same as a regular SI motor. Same amount of torque and roughly the same hp. The heads and IMs are different but really dont make all that much difference in power.
yup the motor should have close to the same power as an si but as far as running up against another gsR or even an si forget about it the power won't be enough to haul the weight of the integra seeing as how civics weigh less i say throw in a b18c1
my friend's has that combo in an eg civic and it moves it's weight real good, but i agree that a c1 block would be better suited in an integra. whats he asking for the car anyway, it all depends on the price and condition of the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRider98 »</TD></TR><TR><TD CLASS="quote">agreed that it will be slower than a gsr but the si head isn't always the better head. i'm sure i don't need to explain why. </TD></TR></TABLE>
Yea, I struggle everyday to understand why everybody always says the SI head is better. The flow tests have been shown time and time again and the air flow is nearly identical on both heads. How and why is the SI better?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white ex »</TD></TR><TR><TD CLASS="quote">i think the reason people believe that the b16 head is better is because honda used that casting for the type-r, so people just automatically assume it's better.</TD></TR></TABLE>
Oh sizzle......the "Type R." I find it funny because if you actually look at ALL of the upgrades honda did (P&P, cams, valvesprings, valves, raised compression, intake manifold, redesigned/modified intake, header, exhaust, etc) and they got 25hp at the crank. Then people magically think the cams are going to add 25hp to their car......**** trips me out every time.
