gsr rods...
Old Nov 13, 2006 | 08:46 PM
NA JDM GSR's Avatar
Default gsr rods...
is it possible to take the pistons out of the rods or their stuck on there for good???
Old Nov 14, 2006 | 05:06 AM
IN VTEC's Avatar
Default Re: gsr rods... (NA JDM GSR)
You can heat up the rod and press the wrist pin out, but a lot of times the pistons get distorted or crack under the pressure.
Old Nov 14, 2006 | 08:00 AM
95 integra's Avatar
Default Re: gsr rods... (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">You can heat up the rod and press the wrist pin out, but a lot of times the pistons get distorted or crack under the pressure.</TD></TR></TABLE>
yep, the rod can be reused, the pistons will almost always be trashed. They make a special tool to press the pin out without trashing it but almost nobody has it.
Old Nov 14, 2006 | 08:30 AM
IN VTEC's Avatar
Default Re: gsr rods... (95 integra)
Even with the tool, the wrist pin can sometimes snag the piston and try to carry the skirt out with the pin.
Old Nov 14, 2006 | 09:17 AM
NA JDM GSR's Avatar
yea i got new wrist pins and pistons anyways so i should b good
Old Nov 15, 2006 | 04:47 PM
NA JDM GSR's Avatar
u think a machine shop can take out the pistons and the pins?
Old Nov 15, 2006 | 05:24 PM
95 integra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA JDM GSR &raquo;</TD></TR><TR><TD CLASS="quote">u think a machine shop can take out the pistons and the pins?</TD></TR></TABLE>
Yes or anybody with a press...given the pistons will be trashed, but the rods will be fine.
Old Nov 15, 2006 | 06:19 PM
NA JDM GSR's Avatar
damn... cuz i tried heating up the rod and slipping the wrist pin in and it cooled down too quickly and now the wrist pin is half out and half in with brand new jdm itr pistons...
Old Nov 15, 2006 | 07:06 PM
95 integra's Avatar
Machine shop should be able to take care of that for you....though it may or may not work. I did the same my first try and the machine shop was able to press it in fully with no problems. Engine went to 9k everyday, so its possible....though I learned my lesson when it comes to taking certain things to a machine shop.
DOHC_C-REX
34
May 15, 2008 06:23 PM
allmotor99lude
Jan 4, 2006 11:37 AM
turbo_b16_ex
Nov 13, 2005 02:00 PM
PYITR821
Sep 13, 2005 07:33 PM
tegasaurus
Jul 15, 2004 01:09 PM
