90 hatch , idles real low, showing code 13
Old Nov 13, 2006 | 08:39 PM
05si90hatch's Avatar
Default 90 hatch , idles real low, showing code 13
Soooo,
I've got this 90 hatch....
It idles very low..
If you give it over half throttle it acts like it is running on 2 cylinders until it reaches 4k+rpm at which point it begins to run incredible...
ECU gives code 13...
Interesting thing is the car ran fine for about 2 years giving me that code and being it was my work car I just over looked it. Originally I thought I may have gotten a tank of bad gas due to the way the car was acting, so I drained tank and replaced the fuel filter with no luck. From that point I went on to replace:
O2 sensor
distributor(off of another toy, ran fine on it)
plugs/wires
Any ideas what is going on and what I should do to troubleshoot the code 13????
Old Nov 13, 2006 | 09:04 PM
placid888's Avatar
Default Re: 90 hatch , idles real low, showing code 13 (05si90hatch)
u should have check what code 13 is before doing anything else, code 13 is for ATMOSPHERIC PRESSURE sensor
Old Nov 13, 2006 | 10:49 PM
Default Re: 90 hatch , idles real low, showing code 13 (placid888)
this i know
eveything I have found on this states it is on the ecu.. swapped it too
Old Nov 14, 2006 | 06:38 AM
wiZCo's Avatar
Stouts 'n' Scotch
Your MAP sensor needs to be replaced.
Old Nov 14, 2006 | 08:49 AM
Default Re: 90 hatch , idles real low, showing code 13 (wiZCo)
Update
I found the atmospheric sensor... its mounted to the passenger side kick panel...it was unplugged(hahahahaha) so no check light but still runs like trash.
SO next I guess I will try swapping the MAP off of my other ride.
Thanks for advice
happyabortion
May 13, 2008 04:18 PM
joenoreason
Jan 20, 2007 03:17 PM
ImThatGuy
Jul 8, 2005 08:02 AM
Vindicator9000
10
Jun 22, 2005 05:44 PM
98slvrcx
Aug 1, 2003 10:49 PM
