Jdm Type R Rims or Usdm Type R rims
Old Nov 13, 2006 | 06:23 PM
blkboyan's Avatar
Default Jdm Type R Rims or Usdm Type R rims
Dear All,
Do you guy have any idea, I have 2000 Yellow ITR , so i want to to change the rims, the Jdm look is better or Usdm is better, also what kind the color is good for my yellow ITR ( White color or Gunmetal color ?) tks
Also i have another questions
What band the High Flow Cat is better ? or do i usa back the factory ITR cat ? and i want to know is the Factory ITR cat is better ? or after market cat is better ? or Test pipe is better ? ( i mean performace)
tks for help
Old Nov 13, 2006 | 06:26 PM
nautica_t's Avatar
i say jdm rims but get gm since your PY.
but thats up to you whatever you like.
BlueIntegraBoy's Avatar
Default Re: Jdm Type R Rims or Usdm Type R rims (blkboyan1486)
The look is all up to you. I like the JDM rims. Gunmetal looks best with PY.
Old Nov 13, 2006 | 06:29 PM
Doostur's Avatar
I got a 98 CW ITR.... I love the stock 15'' whites but I also have 16'' white jdms. Then again I love the Stock usdm Gunmetal oem rims and even more the 16'' jdm gunmetals. I know it dosn't help but i suggest you buy the set of JDM wheels you like but keep the stockies too!
Old Nov 13, 2006 | 06:31 PM
Doostur's Avatar
Default Re: Jdm Type R Rims or Usdm Type R rims (blkboyan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkboyan &raquo;</TD></TR><TR><TD CLASS="quote">Dear All, </TD></TR></TABLE>
Old Nov 13, 2006 | 10:08 PM
MK Ultra's Avatar
I like the USDM wheels, because I prefer 15s to 16s on a car as small and light as an Integra. The 15s offer lower unsprung weight, a tighter turning circle, and, IMO, better steering feel.
As for cats, you don't need an aftermarket cat unless you plan on using a header with a larger diameter collector. There is no practical performance advantage to using a test pipe at all. If you're using a stock size header, the stock cat will work fine.
Old Nov 13, 2006 | 11:21 PM
blkboyan's Avatar
Default Re: Jdm Type R Rims or Usdm Type R rims (MK Ultra)
oic tks MK Ultra
but my ITR i change the DC header already , so what do you think
Old Nov 13, 2006 | 11:30 PM
tartje's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MK Ultra &raquo;</TD></TR><TR><TD CLASS="quote">I like the USDM wheels, because I prefer 15s to 16s on a car as small and light as an Integra. The 15s offer lower unsprung weight, a tighter turning circle, and, IMO, better steering feel.
which is why UKDM 15's are the best choice
Old Nov 13, 2006 | 11:54 PM
MK Ultra's Avatar
What size collector does your DC header have? If it's the 2" collector, it will bolt up to the stock cat, and will be fine as is. If you got the one with the larger 2.5" collector, you'll need an aftermarket cat to fit it.
I get the impression that the header is already on the car. If it is, and it bolted up to the stock cat, you've got nothing to worry about. The best thing to do is to continue using your stock cat.
The UK-spec wheels, I believe, are a bit lighter than the U.S. version, so yes, they are a good choice.
Old Nov 14, 2006 | 05:11 AM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Jdm Type R Rims or Usdm Type R rims (tartje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje &raquo;</TD></TR><TR><TD CLASS="quote">which is why UKDM 15's are the best choice </TD></TR></TABLE>
Best ITR wheel ever
Old Nov 14, 2006 | 07:07 AM
walker111's Avatar
Default Re: Jdm Type R Rims or Usdm Type R rims (Splat)
Renault cat is pretty good
Old Nov 14, 2006 | 01:45 PM
justink4's Avatar
tks for help </TD></TR></TABLE>
FYI: I have a set of JDM's for sale, PM if you are interested
https://honda-tech.com/zerothread?id=1809761
Old Nov 14, 2006 | 01:50 PM
blkboyan's Avatar
Default Re: Jdm Type R Rims or Usdm Type R rims (justink4)
hi
tks your pic so how much you go to sell your rims
Tks
Old Dec 2, 2006 | 04:34 PM
jnuanz382's Avatar
is the ITR rims fit on 97 honda prelude???? anyone????
Old Dec 2, 2006 | 05:59 PM
Default Re: Jdm Type R Rims or Usdm Type R rims (jnuanz382)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jnuanz382 &raquo;</TD></TR><TR><TD CLASS="quote">is the ITR rims fit on 97 honda prelude???? anyone????</TD></TR></TABLE>
Don't know if the 15's will clear the caliper.
Old Dec 2, 2006 | 06:55 PM
94rs-turbo's Avatar
https://honda-tech.com/zero...ge=20 thread has it all scroll down to see cw on py
Old Dec 2, 2006 | 11:06 PM
waddy41's Avatar
they're both nice......get gunmetal !
Old Dec 2, 2006 | 11:11 PM
Doostur's Avatar
JDM GM's!!! I had this same question thread a month ago... I got me some White JDMS!
OUT OF ORDER ROB
Jan 28, 2006 09:19 PM
SilverDc2
Nov 18, 2005 05:15 PM
Bay_707
Apr 4, 2005 09:39 PM
jdmekrsi
Aug 3, 2004 06:00 PM
SCsol
May 5, 2002 04:08 PM
