PLEASE HELP? Major brake problems
Old Nov 13, 2006 | 01:35 PM
Moshimoto racing's Avatar
Default PLEASE HELP? Major brake problems
hey, I own a 1994 acura integra ls, and i have been having some issues with my anti-lock brakes. When i start the car up in the morning, sometimes the abs buzzes and sometimes it doesn't.
When the abs light is on , my brakes are fine and work with no problems. When the abs light is not on, when i come to a stop the brakes skip about 3-4 times before i can stop. In the past week it has gotten really worse. anyone have any ideas on what is wrong with it?
Old Nov 13, 2006 | 01:43 PM
dvp's Avatar
dvp
Default Re: PLEASE HELP? Major brake problems (tegnation22)
When was the last time you checked the fluid?
What do you mean skipped?? Are you having to pump the peddle? Does the peddle go to the floor slowly when pushed. Or do you mean the ABS engages way early?
Old Nov 13, 2006 | 01:47 PM
Default Re: PLEASE HELP? Major brake problems (dvp)
just checked the fluid todays, it between about the min. and the max. when i engage the brakes to stop it seems like there not cathching "they grind" and make a very loud noise(it only happens when i come to a complete stop). im gonna throw some more fluid in there tommorow.
Old Nov 13, 2006 | 01:53 PM
dvp's Avatar
dvp
Sounds like you might not have any pads left. Have you checked those? Metal on metal is not a good thing. The further down the pads get the worse the peddle feel.
Old Nov 13, 2006 | 02:44 PM
then why would the bas be involved, when the lights on there fine, when the lights off there no good?
Old Nov 13, 2006 | 02:54 PM
dvp's Avatar
dvp
What!!??
You say you have a grind but you wont go check the pads...one thing at a time.
Old Nov 13, 2006 | 03:03 PM
i cant tonite, its 25 degreess out and pouring rain, and my car is iced over.
new england weather bro
Old Nov 13, 2006 | 05:14 PM
bump
Old Nov 13, 2006 | 05:46 PM
Dogginator's Avatar
Daisy... Daisy...
I have similar symptoms on my car. I have a bad LR wheel sensor which has a high impedance. I received codes 4-8 and 5-8. Did you pull your ABS codes?
Old Nov 13, 2006 | 05:53 PM
Default Re: PLEASE HELP? Major brake problems (Dogginator)
No, how would that be done?
Old Nov 13, 2006 | 05:58 PM
Dogginator's Avatar
Daisy... Daisy...
There is an instruction thread in the Forum FAQ.
Old Nov 15, 2006 | 05:58 AM
bump
Old Nov 15, 2006 | 06:06 AM
Dogginator's Avatar
Daisy... Daisy...
What were the stored ABS codes? You most likely have a faulty sensor. The codes will tell you which sensor is the problem.
Komakazi_830
Aug 5, 2008 10:38 AM
kenneyd
Feb 23, 2007 07:24 AM
blackpearlv6
May 31, 2006 03:44 PM
dclute
Sep 27, 2004 03:17 PM
Teknic73
Jan 19, 2004 08:27 PM
