supercharge header question
It is the Kamikaze header. There have been fitment issues with this header, but it is still the best for a JRSC'd ITR. I believe they are about 300 new, so the price isn't too bad.
Best bang-for-the-buck: Endyn "modified" Kamikaze header.
Cost: $309
Yes there are better options, such as the LHT header, but the cost ($995) does not justify what performance gains you will see over the kamikaze, IMHO.
NOTE: Although it is called Endyn "modified," It is not manufactured or modified by Endyn-- it is constructed by Kamikaze to Endyn's specifications. Because of this, certain issues that are common with a regular kamikaze header are also common with the Endyn "modified" Kamikaze header. The most common issue is fitment, which can generally be fixed by any muffler/exhaust shop cheaply if you can not do it yourself.
Cost: $309
For the Money you Can't beat the Kamakazi, Most people don't make enough power to see the gains per $$$ for the LHT header. When you are extracting the most gains possible you need to do the best possible parts and that's were all the R+D went .
We will be relaesing a New header we have worked on which is built over sea s, 100% Stainless which runs a true merge collector and 23" tubes which will make good gains and will be about $550 -$600.
pr3B20pwr
Jan 20, 2005 07:29 AM
