GSR rear disc with stock front brakes. Good idea?
Old Nov 13, 2006 | 01:03 PM
stehigs321's Avatar
Default GSR rear disc with stock front brakes. Good idea?
I'm able to get a great deal on a rear disc conv. for my 96 coupe ex. I havent upgraded the brakes on the front for gsr, but am waiting to install new brembo blanks and hawk pads on the front. Would it be ok to run the stock ex brakes on the front with the gsr rear discs?? also, will the rear disk off a gsr fit under my steelies?? Thanks alot
Old Nov 13, 2006 | 01:07 PM
nighttrain33's Avatar
Default Re: GSR rear disc with stock front brakes. Good idea? (stehigs321)
Yes and yes. My GSR rears fit under my 14's just fine. I also have stock '97 ex fronts, and my braking is just fine.
-Shane
Old Nov 13, 2006 | 02:52 PM
SiRek4
Guest
Posts: n/a
Default Re: GSR rear disc with stock front brakes. Good idea? (nighttrain33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 &raquo;</TD></TR><TR><TD CLASS="quote">Yes and yes. My GSR rears fit under my 14's just fine. I also have stock '97 ex fronts, and my braking is just fine.
-Shane</TD></TR></TABLE>
i too have stocks on my ek and the rears are si. my brakes feel perfect.
Old Nov 13, 2006 | 02:55 PM
BlueIntegraBoy's Avatar
The EX front rotor size is 10.25" as well as the Integra. The only difference between the EX and Integra are the calipers. In actuality, you will have the same braking power as a Civic Si (same calipers and rotor size as EX).
Old Nov 13, 2006 | 03:48 PM
EL Vap133's Avatar
Yes you'll be fine, and you will appreciate replacing the pads on the discs than on drums.
95_GSR_SEDAN
17
Dec 9, 2009 04:25 PM
SHO-NUFF
20
Apr 12, 2007 07:22 AM
gsrhb7
Northwest (Sales)
Apr 7, 2007 02:54 PM
redman223
Apr 10, 2002 03:29 PM
