bottom end rebuild??? price????
Old Nov 13, 2006 | 12:21 PM
Blk-dc2's Avatar
Default bottom end rebuild??? price????
my car goes through a qt and a half of oil every 3 to 4 weeks...
i'm thinking bad piston rings..
so if i were to rebuild my bottom end , i just wanted to see what the price range would be for a good setup. and also what knid of setup would be good....b18c1
anybody....
thanks
Old Nov 13, 2006 | 12:23 PM
thatwhiteguy's Avatar
Default Re: bottom end rebuild??? price???? (BLACK-dc2)
bump for same problem
Old Nov 13, 2006 | 12:25 PM
Blk-dc2's Avatar
Default Re: bottom end rebuild??? price???? (thatwhiteguy)
my friend gots the same problem on his 98 gsr
Old Nov 13, 2006 | 12:32 PM
aaronISthrowed's Avatar
Did you want aftermarket parts or OEM?
Old Nov 13, 2006 | 12:35 PM
Blk-dc2's Avatar
Default Re: bottom end rebuild??? price???? (aaronISthrowed)
i would like do something better, maybe some itr pistons or what ever....
Old Nov 13, 2006 | 12:41 PM
Blk-dc2's Avatar
i was thinking type-r piston, gsr crank n rods.......what you think
Old Nov 13, 2006 | 12:44 PM
qwk db8's Avatar
from what iv herd it woul be best if u put a d15 in ur car
Old Nov 13, 2006 | 12:45 PM
Blk-dc2's Avatar
Default Re: bottom end rebuild??? price???? (qwk db8)
is that what you got in your car with the steelies on it????
Old Nov 13, 2006 | 12:47 PM
Blk-dc2's Avatar
are you the same guy who own the 92 prelude with the focus headlight conversion?????
Old Nov 13, 2006 | 12:48 PM
qwk db8's Avatar
youre just mad because my steelies are cleaner than ur rota gt3s and my single cam still puts a car lenght on u
Old Nov 13, 2006 | 12:50 PM
Blk-dc2's Avatar
but isn't your integra fake....i thought it was a chevy cobalt with a teg front end.....
and i'm rollin on gabs
Old Nov 13, 2006 | 12:51 PM
qwk db8's Avatar
no but i seen ur car with the hyndai elantra conversion
Old Nov 13, 2006 | 12:52 PM
qwk db8's Avatar
ur gabs seen more cubs than red paint
Old Nov 13, 2006 | 12:54 PM
Blk-dc2's Avatar
i seen you at fremont honda meet are the same guy that is siting on his white da
automatic....................
Old Nov 13, 2006 | 12:56 PM
qwk db8's Avatar
wasint me but good looking out
Old Nov 13, 2006 | 01:10 PM
Blk-dc2's Avatar
is this your car....i seen you in a pic the other day on ht sitting in front of it....
Old Nov 13, 2006 | 01:17 PM
juda7's Avatar
Sleeving the block might be a good idea.
Old Nov 13, 2006 | 01:18 PM
Blk-dc2's Avatar
Default Re: bottom end rebuild??? price???? (juda7)
i was thinking about that, because i don't know how the cylinder walls look...
Old Nov 13, 2006 | 01:26 PM
Wayne_Curr's Avatar
My car leaks about the same amount of oil and its the cam seal. Have you replaced that yet? Start simple on fixing your leak before you go and rebuild your whole bottom end.
Unless you're actually WANTING to spend all that money. Do a compression test also before you assume bad rings
Old Nov 13, 2006 | 01:56 PM
Blk-dc2's Avatar
Default Re: bottom end rebuild??? price???? (Wayne_Curr)
no, i haven't check that out yet, but thanks, if there was a cam seal leak wouldnt i see a leak around the head?????
Old Nov 13, 2006 | 01:59 PM
Blk-dc2's Avatar
another reason why i think its bad piston rings is, when i get on my car i can see alot of gray smoke coming out of the back....i don't if thats really bad or not.
my friend car does the same but he dosen't go through as much oil as i do
Old Nov 13, 2006 | 02:02 PM
Wayne_Curr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLACK-dc2 &raquo;</TD></TR><TR><TD CLASS="quote">another reason why i think its bad piston rings is, when i get on my car i can see alot of gray smoke coming out of the back....i don't if thats really bad or not.
my friend car does the same but he dosen't go through as much oil as i do </TD></TR></TABLE>
Have you checked your spark plugs? See if there is any oil on them or if they are black as tar.
Old Nov 13, 2006 | 02:05 PM
Blk-dc2's Avatar
they are a lil black, but know oil on them..
Old Nov 13, 2006 | 02:16 PM
Wayne_Curr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLACK-dc2 &raquo;</TD></TR><TR><TD CLASS="quote">they are a lil black, but know oil on them..</TD></TR></TABLE>
I really doubt your rings are a cause for concern right now.
Old Nov 13, 2006 | 02:22 PM
Blk-dc2's Avatar
thanks, i'll look at the cam seal.....
