open cam gears?
Old May 7, 2002 | 08:23 PM
xXx Justin xXx's Avatar
Default open cam gears?
anyone have any pics of there engine with open (exposed) cam gears?? please postem
Old May 7, 2002 | 08:39 PM
Default Re: open cam gears? (The dx-R CRX)
come on guys i know your out there!!
Old May 7, 2002 | 08:50 PM
JurakS's Avatar
why do you need a pic of te open cam gears? i could get a pic of mine...if ya want..maybe tomorrow
Old May 7, 2002 | 08:52 PM
Default Re: open cam gears? (Juraks)
i have a d16z6 going into my rex. i am tring to decide if i want to buy a cam gear for it or not. if i buy one it will be only for cosmetic reasons. i just want to see how stupid ( if at all ) it looks with half of the timing cover missing, and the bottom half still there....
Old May 7, 2002 | 08:53 PM
JurakS's Avatar
nvm..i have a b16..sorry
Old May 7, 2002 | 10:21 PM
88civic's Avatar
you can not see the bottom half when motor is in car.but if you wnat you could cut out the bottom half or do it the right way and remonve the pully. have fun doing that!!
Old May 7, 2002 | 10:24 PM
Malgerus's Avatar
heh heh mine came with one, AEM too!
Old May 8, 2002 | 06:58 AM
keithv's Avatar
Default Re: open cam gears? (C5_ALLMOTOR)
if you want something to drop down into your timing belt and bend all your valves, then go ahead and do it...
Old May 8, 2002 | 07:32 AM
therealciviczc's Avatar
A performance part for cosmetic reasons looks stupid no matter what it is. Why not spend the same cash on something you can feel?
Here are two really really old pictures of my car....
http://www.geocities.com/civiczc/intake/cmgear1.jpg
http://www.geocities.com/civiczc/intake/cmgear2.jpg
This is from about 5 years ago and the pictures are small. You'll probably have to cut and paste since its geoshitties.
Old May 8, 2002 | 08:16 AM
-=TWITCH=-'s Avatar
Default Re: open cam gears? (therealciviczc)
ill help you out
Old May 8, 2002 | 09:41 AM
CRX7's Avatar
Default Re: open cam gears? (-=TWITCH=-)
running open cam gears is not safe, mine came cut and I've bought an uncut one to replace it. Even if something large doesn't get in their and destroy your timing belt then the dirt and dust will make your timing belt wear prematurely. After 10000 miles mine was already showing wear on the timing belt running open cam gears.
Old May 8, 2002 | 10:36 AM
BoostedED9's Avatar
Default Re: open cam gears? (CRX7)
heres my friends b16
Old May 11, 2002 | 06:17 PM
kefka's Avatar
Default Re: open cam gears? (ED9Hybrid)
here are my dc's
Old May 11, 2002 | 09:49 PM
flat-blk-HB's Avatar
Default Re: open cam gears? (Lil Cs Zc)
I don't understand why? Unless you have cam gears to adjust maybe but stock gears.....no use...IMO that is. I have heard with a ZC it is sometimes hard for the hood to clear with the cover..Not sure about this though
Old May 11, 2002 | 10:05 PM
Default Re: open cam gears? (ED6)
i was going to do it and use adjustable aem or skunk2 gear. but now i have talked my self out of it, i just wish i could get the bitch wired...
Old May 12, 2002 | 01:36 AM
CRX7's Avatar
how many times are you going to adjust them anyways, the one or two times you go to the dyno yes. otherwise open cams are for show.
Old May 13, 2002 | 11:29 AM
keithv's Avatar
for what its worth, i have a ZC with the cover on the cam gears and it doesn't hit the hood.
Old May 13, 2002 | 11:33 AM
turbo_ef9's Avatar
Default Re: open cam gears? (breaka_1_9)
heres my old motor... semi built b16 sold to a fellow H T member..
Old May 13, 2002 | 09:30 PM
That's cool. Did you have to cut a piece of the support out or anything?
Old May 13, 2002 | 10:07 PM
martini's Avatar
Old May 16, 2002 | 06:21 AM
keithv's Avatar
nope, no cutting of the hood support or anything. fits fine under there.
CRXherbie91
Aug 22, 2010 08:30 PM
lude98SH
Aug 9, 2007 11:51 AM
mike93boost
Apr 5, 2006 05:46 PM
NoVtecLs
Oct 10, 2004 11:01 PM
Red Rocket
Feb 11, 2002 05:10 PM
