99 gsr want to go turbo
Old Nov 13, 2006 | 11:20 AM
99gsrSkI's Avatar
Default 99 gsr want to go turbo
I juz picked up a 99 gsr with 77k after reading acouple of articles I seen a patern
alot of us integra 1.8L owners are going turbo. Well heres my question I would like to make my gsr turbo...... I still want this car to be a daily driver so reliability is a must.....
Were do I begin?
Engine and car are stock....
Old Nov 13, 2006 | 11:38 AM
TurboGS-R's Avatar
Default Re: 99 gsr want to go turbo (99gsrSkI)
You should begin by doing a SEARCH (near the upper right corner) and read up on what people have to say. As far as I know, only the Greddy kit w/o intercooler and maybe a JG Edelbrock kit are STREET LEGAL.
Old Nov 13, 2006 | 11:59 AM
99gsrSkI's Avatar
will run a search
thanks man new to this website but so far is great
good lookin out
Old Nov 13, 2006 | 01:37 PM
deryck324's Avatar
well i would recamend just peicing one together for the type of driving and amount of boost you would be running
Old Nov 13, 2006 | 02:21 PM
evan938's Avatar
im in the same boat right now. just picked up a 95gsr and working on a turbo kit for under 1500$
im planning on used manifold, t25 turbo w/ internal wastegate, dsm SMIC, 2.25" piping, 3" DP/cat into 2.5" apexi ws2 catback, still trying to decide on tuning...going to be running 6-8psi MAX until i feel i need more and want to build the engine up to handle it
Old Nov 13, 2006 | 04:07 PM
95teg_ls's Avatar
Default Re: (evan938)
is everyone with turbos running forged internals?? ive seen a lot of people recommend itr pistons, but how much boost can you run without forged internals??
Old Nov 13, 2006 | 04:57 PM
DS002's Avatar
Banned
Default Re: (95teg_ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95teg_ls &raquo;</TD></TR><TR><TD CLASS="quote">is everyone with turbos running forged internals?? ive seen a lot of people recommend itr pistons, but how much boost can you run without forged internals??</TD></TR></TABLE>
who is recomending ITR pistons for a turbo build ? They arent even forged , theres way more factors than just psi . Look into how much air it actually flows .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evan938 &raquo;</TD></TR><TR><TD CLASS="quote">im in the same boat right now. just picked up a 95gsr and working on a turbo kit for under 1500$
im planning on used manifold, t25 turbo w/ internal wastegate, dsm SMIC, 2.25" piping, 3" DP/cat into 2.5" apexi ws2 catback, still trying to decide on tuning...going to be running 6-8psi MAX until i feel i need more and want to build the engine up to handle it</TD></TR></TABLE>
you can run way more than that with a T25 and you will be fine
Old Nov 13, 2006 | 05:36 PM
Sam92Teg's Avatar
Not only do you have the search button at your disposal, but there is a 'forced induction' forum that has post after post of stock GSR's boosted from mild to wild.
Old Nov 13, 2006 | 05:38 PM
evan938's Avatar
Default Re: (DS002)
i know i could, but i dont want to run the risk of something happening, and getting stuck with having to shell out thousands of dollars for a new engine. 6-8 psi will be more than enough for me...im coming from a 140whp elantra (modded) to a stock 95gsr, which is quicker than the elantra was with all my mods to it. i figure 6-8 psi i should be able to hit 220ish whp, which will be enough to put a nice grin on my face
like i said, if im gonna go for high boost, im gonna do it the correct way, and its not going to be with a stock long block. until i get a second income or a nice raise at work, its gonna be a while before i can afford a new engine to set aside and build up
Old Nov 13, 2006 | 05:41 PM
95teg_ls's Avatar
Default Re: (DS002)
i knew the itr pistons werent forged, but i just heard a lot of people using them, but i dont know if they were boosted.
Old Nov 13, 2006 | 05:44 PM
sospeed's Avatar
ITR pistons wounldnt be good not bc they are not forged but bc they would give you way to much compression for a turbo engine.
Old Nov 13, 2006 | 05:48 PM
sospeed's Avatar
I myself am trying to plan a build and am doing my home work first. I am looking to buy a 96-01 ls integra. I am shooting for 10,000 for a full build. Thats tuning, engine tranny, turbo, engine managment, suspension, brakes, wheels and tires
Old Nov 13, 2006 | 06:59 PM
.Smitty.'s Avatar
Just a quick question. How much flow will you get from the WS2? I'd really like something quiet and stockish looking but if I ever go turbo I don't wanna restrict the air via exhaust.
ps...look at all the noob avatars in a row..scary
Old Nov 13, 2006 | 07:25 PM
TurdBlown Teg's Avatar
if you want to be some what quiet do a random cat back its 2.75 and not loud thats what i am using
Old Nov 13, 2006 | 09:02 PM
evan938's Avatar
2.75" is insane for a catback. 2.5" single will support up to 400hp.
you can check out this chart directly from maximum boost by corky bell
http://mahonroy.home.comcast.n...d.jpg
Old Nov 13, 2006 | 09:41 PM
DS002's Avatar
Banned
Default Re: (sospeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sospeed &raquo;</TD></TR><TR><TD CLASS="quote">ITR pistons wounldnt be good not bc they are not forged but bc they would give you way to much compression for a turbo engine.</TD></TR></TABLE>
Are you serious ? People do high compression/low boost all the time , its all in the tuning . A forged piston will handle way more pressure than a cast piston .
Old Nov 14, 2006 | 06:09 AM
sospeed's Avatar
Default Re: (DS002)
But why would you want to do that?? You know you are going to be limited bc of your pistons. You are better off just buying a lower CR piston from the start. And yes you are right about the tunning but unless you have the right setup you will never be able to run more boost.
Old Nov 14, 2006 | 06:17 AM
neovvl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sospeed &raquo;</TD></TR><TR><TD CLASS="quote">But why would you want to do that?? You know you are going to be limited bc of your pistons. You are better off just buying a lower CR piston from the start. And yes you are right about the tunning but unless you have the right setup you will never be able to run more boost.</TD></TR></TABLE>
You would do that because you can run lower boost but still produce the same numbers.
Old Nov 14, 2006 | 07:36 AM
jdm tommy's Avatar
go to the forced induction forum and read all the faqs
Old Nov 16, 2006 | 03:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evan938 &raquo;</TD></TR><TR><TD CLASS="quote">2.75" is insane for a catback. 2.5" single will support up to 400hp.
http://mahonroy.home.comcast.n...d.jpg</TD></TR></TABLE>
maybe for an n/a car. but for your turbo to breathe 2.75 and up is a must
Old Nov 16, 2006 | 03:57 PM
evan938's Avatar
you're still going to want to have a little back pressure in your exhaust. a 2.5" exhaust will be fine for anything short of having to build up a motor... 3" on a turbo 4cyl is rediculous unless youre running an insane amount of HP.
Old Nov 16, 2006 | 04:35 PM
98tegLSvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sospeed &raquo;</TD></TR><TR><TD CLASS="quote">I myself am trying to plan a build and am doing my home work first. I am looking to buy a 96-01 ls integra. I am shooting for 10,000 for a full build. Thats tuning, engine tranny, turbo, engine managment, suspension, brakes, wheels and tires </TD></TR></TABLE>
hey i got a 98 integra ls with b16 head and ecu, six puck clutch, lowered on skunk 2 springs, alarm,tint and intake for $5000 so all i have to say is shop around
Old Nov 16, 2006 | 09:28 PM
mines stock engine but im building it come next month. and it helps alot from stock and a 2.3" exhaust which i have had before.
Old Nov 16, 2006 | 11:14 PM
Kafelatte's Avatar
just a thought. why not just do a k20a swap? same cost with tuning and factory relaibilty. 220 hp 151 lb. trq
GSRBrent
Jan 15, 2008 09:40 AM
Tomhob
Apr 27, 2007 09:35 PM
jdmxxdc2
Apr 12, 2005 04:49 AM
Lewie
Nov 17, 2002 08:21 AM
94mugenintegra
May 22, 2002 03:17 PM
