wheel studs?
how are the wheel studs changed? i want to go to extended studs and open ended lugs in prepation for new wheels, and will be doing front brakes soon and hopefully a rear disk conversion. is it easy once the disc is off?
thanks (and yes i searched)
You will need to remove the hub, put the studs in, and have the hub pressed back in.
EDIT: https://honda-tech.com/zerothread?id=907985
how long ago have you replaced the bearings, if it hasnt been too long you should be ok i just did extended whhel studs on my buddys hatch and as long as the bearings look good or in your case are new then your in the clear.
Tyson
22
Jul 13, 2002 03:45 PM
