fan not going on!!!!!!!!
my fan just recently stopped turning on, i currently have it hooked on the side-marker, my fuses are not blown, is it my thermostat?...the temp never heats up (when i have the side-marker on), it stays about a quarter of the way....i changed my radiator not long ago i removed my heater fan...what can it be????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLACK-dc2 »</TD></TR><TR><TD CLASS="quote">did you try jumping it from the relay (under the hood fuse box)????
my fan did that to it was the fan switch</TD></TR></TABLE>
i did, fuse blew in the car i think, i dont remember
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skata89 »</TD></TR><TR><TD CLASS="quote">well if it works then its most likely the thermostat</TD></TR></TABLE>
one guy has told me that too....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLACK-dc2 »</TD></TR><TR><TD CLASS="quote">the way i found out it was my fan switch was ,i jumped it from my fan swtch...</TD></TR></TABLE>
huh?
huh?
The fan switch completes the circuit when a specific temp is reached, so jumping the connector to the fan switch will simulate this function. If the fan comes on, then you know it is the fan switch that is faulty. Man I need a job.
Look behind the engine under the throttle boddy. There should be a larger radiator hose back there. You should se a sensor screwed into the housing that hose runs to. If you unplug that sensor with the engine running, the fan should come on. If it doesn't, check the wiring, if it does, check the sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beanMosheen »</TD></TR><TR><TD CLASS="quote">Look behind the engine under the throttle boddy. There should be a larger radiator hose back there. You should se a sensor screwed into the housing that hose runs to. If you unplug that sensor with the engine running, the fan should come on. If it doesn't, check the wiring, if it does, check the sensor.</TD></TR></TABLE>
thanx man, i will do that
NAS95
Jan 15, 2018 01:51 AM
ek_silverback
Dec 22, 2008 09:29 PM
doggworld1233
Aug 27, 2008 04:23 PM
boots420
Dec 23, 2007 03:22 AM
