does h23 bolt up to f22?
Old Nov 13, 2006 | 10:02 AM
themurrell's Avatar
Default does h23 bolt up to f22?
does h23 bolt up to f22 in a 92? i know the trannys the same but does everything else work?
Old Nov 13, 2006 | 10:04 AM
darkspector2.0's Avatar
do you mean does the h23 drop into a S lude?
Hawkze_2.3's Avatar
Default Re: does h23 bolt up to f22? (themurrell)
Does H23 what bolt up to F22 what???? No the engines don't bolt together
You also need to mention if it's F22A or F22B or what....
Old Nov 13, 2006 | 10:28 AM
92blkJDMh22's Avatar
yes it does.....
you can run a bot from the engine hoist point on the H23 to the motor mount on the F22. The bolt has to be 10'' long and 3/4'' or it wont work..... look for an increase of about 20-30 hp and 70-80 lbs of trq
Old Nov 13, 2006 | 12:04 PM
kulrevon's Avatar
Default Re: (92blkJDMh22)
yes search
Old Nov 13, 2006 | 01:49 PM
themurrell's Avatar
i wanted to know if it was a derect swap because the trannys are the same so i wanted to know if its pretty easy or what
Old Nov 13, 2006 | 02:09 PM
mgags7's Avatar
how about we change the "search" button to the "easy" button so noobs like this guy get the damn idea
01Accordf23
Jul 21, 2009 06:26 PM
f23__
May 7, 2007 10:40 AM
championshipwhite93si
Jul 31, 2006 07:56 PM
FlatBlackPrelude
Mar 8, 2006 11:32 PM
dustywebber
Feb 29, 2004 06:35 PM
