Honda S2000 Honda S2000
Tail Shaft Bearing
Old Nov 13, 2006 | 08:47 AM
Startrek's Avatar
Default Tail Shaft Bearing
I have an engine noise that the dealer says is a tail shaft bearing going bad . This item is on national back order and i still havent recieved it. Has anyone had this problem?
Old Nov 13, 2006 | 10:15 AM
evil vapor's Avatar
Default Re: Tail Shaft Bearing (2000RedS2000)
tail shaft bearing? Where is the bearing located? Hopefully the dealer doesn't say the tail shaft.
Old Nov 13, 2006 | 03:28 PM
Startrek's Avatar
Default Re: Tail Shaft Bearing (evil vapor)
tell you the truth i have not a clue what they are talking about and i talked to them today and they said the part will cost 829 dollars so i guess they are talking about the tail shaft????
Modified by 2000RedS2000 at 5:40 PM 11/13/2006
Old Nov 13, 2006 | 03:30 PM
Startrek's Avatar
sorry that 200 for part plus install is 829
Old Nov 13, 2006 | 08:30 PM
S2tripleO's Avatar
Im guessing it is the bearing that sits in the end of the transmission that hold the output shaft in place. I know SR20 trannies have this problem alot. Or at least my friends who run them have.
Old Nov 13, 2006 | 08:32 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000RedS2000 &raquo;</TD></TR><TR><TD CLASS="quote">tell you the truth i have not a clue what they are talking about and i talked to them today and they said the part will cost 829 dollars so i guess they are talking about the tail shaft????
Modified by 2000RedS2000 at 5:40 PM 11/13/2006</TD></TR></TABLE>
ask them what part of the car the part is for, rear end/differential, transmission, etc.
Old Nov 13, 2006 | 08:33 PM
evil vapor's Avatar
Default Re: (S2tripleO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2tripleO &raquo;</TD></TR><TR><TD CLASS="quote">Im guessing it is the bearing that sits in the end of the transmission that hold the output shaft in place. I know SR20 trannies have this problem alot. Or at least my friends who run them have. </TD></TR></TABLE>
It's the first I've heard of failing, unless it's related to the differential.
Old Nov 14, 2006 | 07:11 AM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: (evil vapor)
Should he check if all of his propeller shaft bolts are there? An unbalanced shaft would be hell on the bearings.
Old Nov 17, 2006 | 11:06 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (FR-MOB: Projekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">Should he check if all of his propeller shaft bolts are there? An unbalanced shaft would be hell on the bearings.</TD></TR></TABLE>
yup..
if the drive shafts arent balanced... you will notice...
has you driveshafts been removed/ replaced?
princetom
Mar 24, 2015 07:16 AM
theYBLEGAL
Transmission & Drivetrain
Aug 20, 2013 11:50 AM
acco
Jun 29, 2010 10:14 AM
garyc17
Feb 4, 2009 04:53 AM
12345
Jun 24, 2005 07:04 AM
