Fuel pump Cut-Off switch wiring, Where do the fuel pump wires run through?
I want to install a hidden switch to cut off power to the fuel pump as added security for my car when parked but have no idea of where the wires to the fule pump run through.
can anyone shed some light on this? I really dont want to start looking under the carpet of the whole cabin to find it
Thanks
Modified by Quick Silver at 9:45 PM 11/13/2006
Thanks
Make sure the connections are very tight....soldered is better. If you loose fuel pressure from a bad electrical connection you could fry your engine quickly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt »</TD></TR><TR><TD CLASS="quote">Get it at the source. Look under the plastic tray that is under your softtop.</TD></TR></TABLE>
worst place to do it.
remove your spare, pop the left cover open and there you have it.
solder everything, those fast champ falls off with vibration, you don't want it to happen when you are vtecking
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head »</TD></TR><TR><TD CLASS="quote">
solder everything, those fast champ falls off with vibration, you don't want it to happen when you are vtecking</TD></TR></TABLE>
We're talking about the same place, hero, except you went through the trunk.
DOHCgarage919
Oct 12, 2007 02:18 PM
