91 crx clutch cable stretching
Old Nov 13, 2006 | 07:11 AM
mi moms crx's Avatar
Default 91 crx clutch cable stretching
i have a 91 crx and the kid i bought it from thought it would be a great idea to put a stage 3 clutch in the car.Now every time i drive the car i end up under neath the hood adjusting the cable is there any possible way to fix this or just change the clutch?
Old Nov 13, 2006 | 07:34 AM
65stang90crx's Avatar
Default Re: 91 crx clutch cable stretching (mi moms crx)
That is WAY overkill! If that is a stock engine or even a swap ZC or something, a stock clutch from autozone is good enough. That stage 3 clutch has soo much clamp it will catch any RPM range from a 200 HP car and put it straight to the wheels!! There is no sense in that. If you want to spend money a ACT or Exedy stage 1 is plenty. At 40-50 per clutch cable I would step that clutch down a little before it breaks.
Old Nov 13, 2006 | 07:53 AM
LilJonWask's Avatar
Default Re: 91 crx clutch cable stretching (65stang90crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 65stang90crx &raquo;</TD></TR><TR><TD CLASS="quote"> I would step that clutch down a little before it breaks.</TD></TR></TABLE>
And just how is it gonna "break" when its a stageIII installed on a stock engine?
Old Nov 13, 2006 | 08:06 AM
Default Re: 91 crx clutch cable stretching (LilJonWask)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LilJonWask &raquo;</TD></TR><TR><TD CLASS="quote">
And just how is it gonna "break" when its a stageIII installed on a stock engine?</TD></TR></TABLE>Dont be stupid. Quote the whole sentence. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 65stang90crx &raquo;</TD></TR><TR><TD CLASS="quote"> At 40-50 per <U>clutch cable </U>I would step that clutch down a little before it breaks.</TD></TR></TABLE>
Old Nov 13, 2006 | 11:06 AM
HondaHeddie's Avatar
You say you have to adj the cable constantly
it wont keep stretching forever
The cable will break
Old Nov 13, 2006 | 11:16 AM
dr_latino999's Avatar
Default Re: 91 crx clutch cable stretching (HondaHeddie)
Hey, just a thought: Make sure the clutch PEDAL isn't seperating from the bracket. Happens quite commonly with over the top pressure plates, and it'll first look like the cable is stretching.
Old Nov 13, 2006 | 11:19 AM
Default Re: 91 crx clutch cable stretching (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Hey, just a thought: Make sure the clutch PEDAL isn't seperating from the bracket. Happens quite commonly with over the top pressure plates, and it'll first look like the cable is stretching.</TD></TR></TABLE>X2
I actually had that happen. Thats why I preach not to overclutch your car! And to adjust your clutch cable properly. I bought 2 clutch pedal assemblys at $100 apiece.
BrainWashed
Aug 18, 2008 05:58 PM
EG_LS
Sep 6, 2007 07:18 PM
jondancer
Jun 9, 2003 02:57 AM
