How To Remove: Passanger Airbag?? 5th gen
Old Nov 13, 2006 | 06:46 AM
fyre's Avatar
Default How To Remove: Passanger Airbag?? 5th gen
anyone have a write up on how to do this on a 5th gen?
Old Nov 13, 2006 | 06:55 AM
fyre's Avatar
Default Re: How To Remove: Passanger Airbag?? 5th gen (fyre)
this is on a 2000. base. and im talking about the passanger airbag.
i know you have to disconnect the battery but is there anyway it could deploy with the battery off?
Old Nov 13, 2006 | 10:51 AM
integra15's Avatar
Once disconnected, the airbag "should" be safe, because of a self shorting connector. However that does not mean it could not go off by some freak accident so be careful.
Old Nov 13, 2006 | 12:19 PM
prelude1897's Avatar
pull your glove box down completely and look under there and you should see 3 10mm bolts that need to be taken out. Once you do that, get a flat head and pry the cover off. They're nothing but pop in clips
Old Nov 15, 2006 | 07:04 AM
fyre's Avatar
Default Re: How To Remove: Passanger Airbag?? 5th gen (prelude1897)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">pull your glove box down completely and look under there and you should see 3 10mm bolts that need to be taken out. Once you do that, get a flat head and pry the cover off. They're nothing but pop in clips</TD></TR></TABLE>
can the airbag cover be placed back on the dash after the airbag is removed?
iJDMBB6
May 14, 2007 05:10 PM
budget
Jan 27, 2007 03:06 PM
RusBear
Dec 16, 2005 01:34 AM
skimeast1982
Dec 9, 2005 05:07 PM
VisPreludeVtec
Mar 3, 2005 05:33 AM
