Anyone knows the weight of this OEM Toyota Rim ??? ITR related
Old Nov 12, 2006 | 08:03 PM
vivid 02's Avatar
Default Anyone knows the weight of this OEM Toyota Rim ??? ITR related
This is a 5 lug rim from a 92-95 Camry. IT is made by Enkei.
It is a 14x6 rim. Reason why I need the info is because I saw a pair at a salvage yard that was closed today. I want them as a cheap set of rear "skinnies" for drag race use.
I also saw of what I believe to be a set of Millenia rims.
Old Nov 12, 2006 | 08:42 PM
RPRacing's Avatar
hot!
Old Nov 12, 2006 | 09:32 PM
MK Ultra's Avatar
Default Re: Anyone knows the weight of this OEM Toyota Rim ??? ITR related (vivid 02)
Well, if they'll only be used as the rear wheels, for drag racing, I don't see how the weight will have all that much of an effect on your times. It's not like you'll have to worry about unsprung weight or overcoming greater rotational inertia in such an application.
And isn't the OEM wheel also 6" wide? Maybe I'm missing something, but I don't see the benefit of using these over stock wheels.
Good luck finding an answer to your question, though.
Old Nov 12, 2006 | 10:35 PM
vivid 02's Avatar
Default Re: Anyone knows the weight of this OEM Toyota Rim ??? ITR related (MK Ultra)
My OEM ITR wheel w/Azenis is 15lbs ITR rim + 22 lbs Tire = 37 lbs x 2 = 74 lbs
Camry Enkei rim might be like the civic hx at 11.74 lbs.
So... 12 lbs + 15 lbs tire = 27 lbs x 2 = 54 lbs
Weight savings of maybe 20 lbs plus less rolling resistance from a 175/70 R14 tire.
Just doing some late night guessing. The presure is on me because I also made a bet that my car will hit a 12.999 or faster by this weekend.
Old Nov 12, 2006 | 11:24 PM
MK Ultra's Avatar
Ah, yes. I can definitely see the benefit of lighter tires (an oft-overlooked part of unsprung weight). Azenis are particularly heavy tires.
Old Nov 13, 2006 | 03:59 AM
ericlee303's Avatar
That rim won't work.
1. Hub bore of Toyota is smaller than TypeR for sure. TypeR hub is huge. That rim won't mount properly without some grinding.
Old Nov 13, 2006 | 05:28 AM
Chris93Si's Avatar
Default Re: (ericlee303)
I *think* those might be 5x100 too, could be wrong but I'm thinking Toyota doesn't use 5x114.3
Old Nov 13, 2006 | 05:52 AM
Todd00's Avatar
I said I don't want a title!
Hub bore is easy to fix via a machine shop. Bolt pattern is not, however.
Just type the car in the tirerack page to see what the bolt pattern is.
Old Nov 13, 2006 | 06:37 AM
RPRacing's Avatar
I know for a fact Toyota MR2s do use a 5x114.3 pattern as I have seen RSX rims on them before. also, i have seen some camry's with MR2 rims on them as well. therefore by syllongism, Camry's have 5x114.3
and as stated above, machine shop can open up your hub bore.
I was looking into using the RX7 spare rims with a skinny 16" tire, but when i ordered one and got it in my hands, i decided to sell it because it was heavy as hell. I'm going to try to use the volksk with some skinny tires stretched VIP style next year.
Old Nov 13, 2006 | 06:43 AM
Utilitarian's Avatar
Will 14's clear the calipers?
Old Nov 13, 2006 | 11:35 AM
vivid 02's Avatar
Default Re: (RPRacing)
i have also seen the RX7 enkei spare rims in 15x4 but they want 100 bucks each....too much for some spare rims.
Old Nov 13, 2006 | 06:06 PM
vivid 02's Avatar
Default Re: (vivid 02)
I went by today and they wanted 60 bucks each..
back to the drawing board
Old Nov 13, 2006 | 07:16 PM
Fo-Do Fanatic's Avatar
are you going to be running with full interior? and all that good ITR stuff?
blackeg
Mar 28, 2010 09:49 AM
98v6AccordDude
Mar 28, 2009 04:50 PM
pumafeet10
Dec 19, 2008 04:57 PM
eyesolation
Jul 16, 2004 11:26 AM
ITR583
Jul 30, 2001 04:27 PM
