Spoon N1 cat or no cat?
Old Nov 12, 2006 | 07:53 PM
JDMDC4life's Avatar
Default Spoon N1 cat or no cat?
When i bought my integra it had a apexi ws with a test pipe which sounds like crap i dont think the world sport was intended to run without a cat becuse with one it sounds just fine.
Anyway i wanted something pritty loud and agressive sounding so i just recently ordered a spoon n1 axle back i plan to bolt up to the apexi mid pipe.
My question is should i put a high flow cat on or just stick with the testpipe?
unlike the world sport dose the Spoon n1 sound good without at cat?
dose n e one have a sound clip of a spoon n1+test pipe?
(i know theres a few clips if you search but most of them dont work ne more.)
Old Nov 12, 2006 | 08:12 PM
Fat Chick Magnet's Avatar
friend has a em1 SI w/ spoon axle back, magnaflow b-pipe, testpipe, headers and it sounds real good. it has a deep tone to it when it hits vtec.
Old Nov 13, 2006 | 10:37 AM
JDMDC4life's Avatar
Default Re: (dc2rtek)
yeah that what im hoping for i cant stand exhausts that get all raspy.
anyone else have some imput?
Old Nov 13, 2006 | 12:59 PM
wakeboard_dude5's Avatar
spoon n1 = most raspy/blatty exhaust i've ever heard. This was on a typeR swapped gsr with comptech header, test pipe, greddy? b-pipe and the spoon axle back. But if it's loud you want this is the exhaust for it. Although i must say it was the best "pissed off bumble bee" sound i've heard from a honda
Old Nov 13, 2006 | 07:49 PM
JDMDC4life's Avatar
Default Re: (wakeboard_dude5)
thats the first person i hurd say the spoon n1 is raspy if that ends up being the case i will most likely end up running a cat.
Old Nov 13, 2006 | 08:31 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (JDMDC4life)
If you don't raspy, you shouldn't be running catless.
Old Nov 13, 2006 | 10:59 PM
want raspy? im running buddyclub spec II on my gsr w/ a testpipe.
Old Nov 14, 2006 | 06:55 AM
Sam92Teg's Avatar
Run a Magnaflow/Carsound cat, $60 and enjoy your Apexi WS.
Old Nov 14, 2006 | 06:59 AM
JDMxDB8's Avatar
Default Re: Spoon N1 cat or no cat? (JDMDC4life)
DC2's are loud w/ spoon N1's w/ a cat already. I suggest that you use a cat, cuz if you went w/ a test pipe, holy crap its gonna be freakin loud.
Old Nov 14, 2006 | 10:45 AM
JDMDC4life's Avatar
Default Re: Spoon N1 cat or no cat? (JDMxDB8)
yeah i will prolly get a carsound cat then. i will be running the spoon n1 with a test pipe for a while though so i wanted to know if the spoon would sound decent that way or at least better then my world sport with the test pipe. I noticed that chamberd mufflers sound like crap with test pipes which is why i thought maybe the n1 would sound better considering its stright though.
Old Nov 15, 2006 | 11:13 PM
calde-da9's Avatar
yep, i agree that spoon-n1s are really loud. sat in the back seat of a db8 with an n1 with out the silencer, but the cat and resonator was still there, from SF to LA and as soon as i got down, i was pretty much deaf for a couple of hours.
Old Nov 18, 2006 | 02:53 PM
Spoon*EK9's Avatar
I don't have a soundclip, but, I do have an N1 with a straight pipe on my EK (itr swap). It can be a LITTLE raspy when letting off the throttle at CERTAIN rpm's. Keep in mind I have one straight pipe between my header and my N1. No resonators. It is pretty loud, but still deep when accelerating.
On my Integra, I had the N1 as well, with test pipe, stock b-pipe, and it sounded VERY deep. I loved it.
My recommendation is to use it w/ the test pipe to see it you like it or not. If it's too loud, put on a hi-flow cat. Good luck!
Old Nov 18, 2006 | 04:31 PM
E-Money's Avatar
You say you dont want raspy, but your going with a N1? My suggestion to you is looking into T1R. They make resonated test pipes and B-pipe sections and all that for DC's. Also I may add look into http://www.sms-products.com, they have custom bolt in cats with the desired diameter you would be looking for.
Old Nov 18, 2006 | 04:51 PM
codenamezero's Avatar
Use a cat, is not gonna make or break the difference with 1HP... get a Hi-flow cat dude... don't pollute the enviroment...
Old Nov 18, 2006 | 05:13 PM
blackdelslo's Avatar
Default Re: (codenamezero)
A resonator will work wonders to any annoying loud exhaust system, the addition of a cat helps to. On my gsr i was running custom exhaust, resonator and a high flow cat and it still had a lot of power and sounded great.
Old Nov 18, 2006 | 05:33 PM
RaceMyGhost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDC4life &raquo;</TD></TR><TR><TD CLASS="quote">thats the first person i hurd say the spoon n1 is raspy if that ends up being the case i will most likely end up running a cat.</TD></TR></TABLE>
why, because its a "spoon?"
Old Nov 22, 2006 | 05:54 AM
JDMDC4life's Avatar
i just put on my spoon n1 yesterday and i would have to say im extreamly happy with the way it sounds with the test pipe. You can acutally hardly hear it when im driving but when i accelerate its loud but sounds amazing which is exactly what i wanted. Its also not raspy what so ever unless im reving but even then it still sounds good.
overall im extreamly happy and i def. think it was money well spent but thanks for the info everyone.
JCL
Jul 6, 2006 12:07 AM
simplegreenmachine
32
Sep 13, 2002 03:14 PM
RaVAGE00
Mar 20, 2002 09:29 AM
SpoonSiR2
10
Mar 12, 2002 07:29 AM
JDM_Type-R
Jan 23, 2002 12:02 AM
