Edelbrock 70mm TB TPS
Old Nov 12, 2006 | 07:16 PM
Hayce's Avatar
Default Edelbrock 70mm TB TPS
Got my new TB in the other day and the TPS plug is not compatible with the honda tps loom plug.
Does anyone know which wire is which so I can put a new plug end on it and match it up with the honda plug?
I searched and found that a user had done this, no response to pm's though...
Any help apreciated
Old Nov 13, 2006 | 03:48 PM
Trooper's Avatar
Default Re: Edelbrock 70mm TB TPS (hayce)
This should help you out
2000 SI
Red/black Input Orange
Yellow/blue Output Green
Green/black Ground Black
1992 - 1995 Civic
Yellow / White Input Orange
Red / Blue Output Green
Green / White Ground Black
1994-1995 Integra LS and GSR
Yellow / Blue Input Orange
Red / Black Output Green
Green / Blue Ground Black
2000-2001 Integra type R
Yellow / Blue 5 volts reference Orange
Red / Black signal out to ecu Green
Green / Black Ground Black
Old Nov 13, 2006 | 03:52 PM
Hayce's Avatar
Thanks heaps Trooper,
I only just got sent that very same thing from a helpful guy at Edelbrock support.
I dont suppose you know if I can adjust the TPS so it only goes as low as .5V?
I have a PowerFC and it throws a code if under around 0.38V.
Old Nov 13, 2006 | 03:59 PM
Trooper's Avatar
Default Re: (hayce)
that Edelbrock tech support guy must be a really nice guy as far as the Apex Power FC im not sure if the voltage rance can be adjsuted.
Old Nov 13, 2006 | 04:05 PM
Hayce's Avatar
Default Re: (Trooper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trooper &raquo;</TD></TR><TR><TD CLASS="quote">that Edelbrock tech support guy must be a really nice guy as far as the Apex Power FC im not sure if the voltage rance can be adjsuted. </TD></TR></TABLE>
Its not you is it? Small ah internet if it is lol
Another guy has looked in an edelbrock manual and thinks I should be able to adjust the tps on the TB to .5 at idle and so long as its &gt; 3.5V at WOT I should be good to go.
Pain the a$$ that the car is in a million pieces otherwise I could just use the "suck it and see method", I hate having to ask questions
accordguy2001
Jan 28, 2008 05:30 PM
TallyS2K
Honda S2000
41
Aug 6, 2005 01:54 PM
2000Accord5sp
May 16, 2003 04:16 PM
Iggy_Type_R
May 14, 2002 08:41 AM
