FS: 88 Crx DX with d15z1 $300 MINNESOTA
I was putting together a 88 Crx with d15z1 swap but its to damn cold and i don't have time for it any more.
All that really needs to be done is put the interior back together (which i should have most pieces)
Things that were just done:
Converted to obd1
New rear shoes
Rotors were turned at that time
New rear left wheel cylinder
Front brakes have a little bit of meat left on them but have been sitting for awhile
New distributor cap
New rotor
New oil pan gasket
Newer o2 sensor (this is the 5wire)
Crx Si front bumper with lip
Interior is somewhat black (black carpet, dash, si door panels)
I have the rear interior panels but I dont think they will work since they are from 90-91 Crx Si (different seat belt positions) but can include)
Things it will need:
1. underdash harness (the one thats in it works but i had 94 Integra dash in it before hand and cut the wiring up to work with it) so the guage cluster works though.
2. Connect coolant lines to the heater hose (i'm bypassing it right now cuz when i installed the motor i didn't have a heater core in the car.
3. Front right wheel bearing (i think)
4. Figure out why its smoking (it could be the headgasket but I"m not positive, could also be something simple)
5. May need tires I gotta see if i have good ones to put on.
6. Needs new front springs
7. Passenger Side door needs to be leveled out
HOODS NOT CLOSED:
A little messy:
Car can be driven home. You just will be missing a dash. Seat belt is hooked up though. Steering wheel and light switch will be put back on.
As you can tell the car has issues but it should be one hell of a gas saver when you get it going and on the road.
-Shane
Iuse2brk@yahoo.com
612-229-8103
Converted to obd1
New rear shoes
New distributor cap
New rotor
New oil pan gasket
HOODS NOT CLOSED:
A little messy:
-Shane
Iuse2brk@yahoo.com
612-229-8103
progress
Feb 27, 2006 08:09 AM
SiR Inspired ED7
Jun 25, 2005 04:47 AM
