99-00 hatch w/ 97 jdm b20 using 99-00 ex harness HELP!
Old Nov 12, 2006 | 06:37 PM
djmatix's Avatar
Default 99-00 hatch w/ 97 jdm b20 using 99-00 ex harness HELP!
So I finally got the motor in, axles in, everything is looking great. My hatch is a 99dx, the motor is a 97 , and the wire harness i'm using is a 99-00 ex harness.
I fed the harness through the firewall and started hooking up sensors. I notice there are a lot of plugs that are exactly the same. Most plug in where they should no problem. I then went around to the passenger side to hook up my d16y7 ECU (99-00). There are 3 plugs coming from the main engine harness that plug into the ecu (2 gray and 1 blue), and one gray plug thats coming from inside the car that has no place to go on the ecu.
So i've got 4 plugs and only 3 plug in. I tried getting the car to power up, but when I turn the key forward past accessories, the fuel pump doesnt turn on, the check engine light doesnt come on, and the main relay doesnt click.
Should I be able to crank the car with that combination? Again, this is my first time dealing with an obd2b car.
Cliff Notes:
99 DX hatch
97 CR-V motor
99-00 EX harness
99-00 DX ECU
car wont power up (no main relay, no fuel pump, no CEL, wont crank)
Any ideas?
Here is what i'm dealing with. Am I running into this because i'm using a 99-00 ex harness with a 99-00 DX ecu? Will a OBD2B>OBD1 jumper harness and p28 fix this problem?
Old Nov 12, 2006 | 07:50 PM
NHswaps13203's Avatar
From: Swapin Motors,Tuckin Bays and Making Harness, CT, USfukenA
Default Re: 99-00 hatch w/ 97 jdm b20 using 99-00 ex harness HELP! (djmatix)
dont worry i can fix............................................... ................
Old Nov 13, 2006 | 10:26 AM
djmatix's Avatar
After doing more research I realized that the Harness the salvage company sent me was a ******* 99-00 NON-VTEC, AUTOMATIC harness.
The little plug thats not plugged in is the damn auto tranny ****.
I'll leave this up for future reference if anyone comes into contact with this setup.
Now I have to convert the iacv to a 2 wire since the autos and non-vtec motors ran 3 wire. No biggie.
Old Nov 14, 2006 | 07:39 PM
h22atchturbo's Avatar
Default Re: (djmatix)
You figured it out? right........
EFityo
Dec 26, 2012 04:26 AM
cage smith
Jun 17, 2012 06:09 PM
girlsaremean
Sep 4, 2007 08:19 AM
ekhunter
Aug 15, 2006 02:09 PM
redcivicek
Oct 1, 2003 08:22 PM
