How do you guys launch?
Are you the kind of person that pumps the gas and launchs or the type that sets it at the same rpm until you launch?
I prefer pumping seems to be easier and a faster method how about you guys?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecallmotor »</TD></TR><TR><TD CLASS="quote">2 step FTW</TD></TR></TABLE>
dumn quetion but whats 2 step?
When you get your crome tuned just make sure the two step is enabled. Two step is a two step rev limiter that sets your rev limiter lower when the car isn't moving. Mine was at around 5500 for the track but some go higher depending on when the turbo spools and/or how much power you're making.
Once both my competitor and myself are staged, I hold the RPM at my desired launch RPM. With just a slight preload on the clutch. Lately I have been using my two-step for more consistent launches.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote"> Once both my competitor and myself are staged, I hold the RPM at my desired launch RPM. With just a slight preload on the clutch. Lately I have been using my two-step for more consistent launches.</TD></TR></TABLE>
Key factor. It helps you be consistent as possible. Pretty much the same thing I do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">2 step + preload .</TD></TR></TABLE>
how do u preload?? is it like riding the clutch??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lobudgetr »</TD></TR><TR><TD CLASS="quote">I rev it to about 8 grand, and as soon as the 3rd yellow drops its piece out, dump the clutch, and hold on.
</TD></TR></TABLE>Have fun with those 3.4 60 fts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM.K20 »</TD></TR><TR><TD CLASS="quote">
how do u preload?? is it like riding the clutch??</TD></TR></TABLE>
assume burnout is done. clutch in first gear. let the clutch out til car lurches forward. grab ebrake. DO NOT PUSH THE CLUTCH IN. half gas. let the ebrake down and let the car lurch into the beams. hit the top yellow, let the other go in, hit your second yellow, and since i am on a 2 step, when the other comes in, floorboard it, yellows drop, let out the clutch fast, and drop ebrake. (my 2 step is triggered off of the ebrake switch.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tokes1320 »</TD></TR><TR><TD CLASS="quote">Bang it off the factory rev limiter and sidestep the clutch
last time i preloaded, i guess i sat there for too damn long, lol i was waiting for the other guy to stage, and finally i launched, 1-2 were good, top of 3rd went straight to red line, 4th was out of boost as soon as it hit boost, straight to red line again, i must have sat there for a long as time for it to slip that bad.
thinking about just launching the ****** with no preload, but then gotta worry about snapping axles
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slo96ex »</TD></TR><TR><TD CLASS="quote">Have fun with those 3.4 60 fts.
im leaving at 8200.......whats wrong with that? im getting 1.6's with 15" wheels....
</TD></TR></TABLE>im leaving at 8200.......whats wrong with that? im getting 1.6's with 15" wheels....
im leaving at 8200.......whats wrong with that? im getting 1.6's with 15" wheels....</TD></TR></TABLE>
im leaven st 9300 on boosted car 1.6 60'
all motor car leaven at 9600 1.57 60'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haza45 »</TD></TR><TR><TD CLASS="quote">
ATTESA E-TS rules
ATTESA E-TS rules
