Treating Stainless Manifolds
Old Nov 12, 2006 | 05:29 PM
Tompen's Avatar
Default Treating Stainless Manifolds
How do you guys go about treating your Stainless manifolds after welding?
I have seen alot of pics where they have just been left as they are but doesnt Stainless rust if not passivated after welding?
Old Nov 12, 2006 | 06:19 PM
MidwestAutoWorks's Avatar
Default Re: Treating Stainless Manifolds (Tompen)
STAIN less
less - no
no stain
Old Nov 12, 2006 | 07:34 PM
TheBandit's Avatar
Generally stainless will hold up just fine as is in the engine bay. It tends to turn pretty colors too.
-Michael-
Just an FYI, just because it is stainless, doesn't mean it is stainproof. Stainless can rust in certain situations.
Old Nov 12, 2006 | 08:52 PM
anusol's Avatar
B A N N E D
Default Re: (TheBandit)
stainless will rust if you polish it or prep it with a mild steel contaminated wire wheel. alos ive seen some 304 stainless rust as well.
Old Nov 12, 2006 | 09:09 PM
RCautoworks's Avatar
Stainless will rust if it gets past a certain heating point.
Old Nov 12, 2006 | 09:33 PM
k24em2's Avatar
Default Re: Treating Stainless Manifolds (90blackcrx)
If you don't clean the HAZ after welding (the rainbow colors) it can rust there.
Old Nov 12, 2006 | 10:33 PM
dave@passenger's Avatar
Default Re: Treating Stainless Manifolds (k24em2)
304 doesn't seem to be the best at corrosion resistance, I personally use mild steel for manifolds and downpipes, and i just get everything ceramic coated after.
Old Nov 12, 2006 | 11:30 PM
Tompen's Avatar
Sweet, so no need to worry for manifolds then?
Old Nov 13, 2006 | 08:21 AM
GeeGee's Avatar
It does take a while for ss manifold to rust, the owner usually got rid of the car/manifold by then.
Old Nov 13, 2006 | 10:41 PM
Tompen's Avatar
Default Re: Treating Stainless Manifolds (GeeGee)
Cheers guys,
Ive got a 304 mug I made about 6 months ago thats starting to develop some surface rust already
Old Nov 13, 2006 | 11:14 PM
beepy's Avatar
I use a stainless steel wire brush to brush all the stainless welding I do. Taking the "pretty colors" off of the welds seems to keep rust from forming.
Also stainless will rust anywhere you touch it with your fingers. I wear gloves on the final install of any parts.
RO_SUNNY
Welding / Fabrication
49
May 15, 2015 06:24 AM
hoochhenry
25
Jan 20, 2012 10:54 AM
rollagti
Apr 28, 2007 09:39 AM
project dc2
Jan 25, 2003 12:24 AM
