Signs of a failing main relay????
The car doesn't start at the first try I turn the key; more like at the tenth.
Car makes that loud click I turn the key and the engine doesn't move, but will start at the 15th try turning the key.
Fuel pump making a "not normal" noise when turning the key into the second position.
I would like to know if it is the main relay acting up on me. It doesn't happen everyday but today I freaked out, the car would just would start, but after the 50th loud click it did. I think it depends of the weather or something. Waht's wrong?
the weather actually does affect it , when it gets hot inside the car it kills the relay, if you don't hear the pump come on it's 99% your main relay, not too sure about a weird noise though......39400-sh3-004
chances are its your relay, mine would act up just like that, Then it didn't do it for a long time so I forgot about it. Well one night at the street races the cops show up, when I went to start my car IT DID IT AGAIN!! finally I got it started and got the hell out of there, Next day I went to NAPA and bought one. I can get em for like $45 through NAPA
Chris
Chris
""Car makes that loud click I turn the key and the engine doesn't move, but will start at the 15th try turning the key""
The main relay will NOT cause this symptom. A low battery, poor cables and connections, starter solenoid, or ignition cylinder will though. The main relay powers up the fuel pump and injectors, plus the ECU.
Brand
21
Sep 8, 2022 09:39 AM
949
45
Jul 3, 2016 12:15 PM
