what TEST PIPE do you guys recommend
Old Nov 12, 2006 | 01:16 PM
Quickridez_3's Avatar
Default what TEST PIPE do you guys recommend
I have stock exhaust but i have a jdm itr header on the way i heard the collector size is different then the normal USDM one what brands carry a J spec one and i am also currently running a stock exhaust system...
ALSO am i going to get a check engine light coming on because i wont be running the Cat and if so how do i elminate this problem
Old Nov 12, 2006 | 01:23 PM
rino924's Avatar
White Trash Wish Cash
Community Builder
Community Influencer
Default Re: what TEST PIPE do you guys recommend (Quickridez_3)
1.) a quality test pipe is the T1R JDM length resonated test pipe
it can be purchased here: http://www.aj-racing.com/catal...age=4
this is a good choice because it eliminates that "raspy" sound a normal straight pipe would produce
2.) you may get a check engine light, it all depends. one thing you could do is raise the o2 sensor using piece that threads into the test pipe and also has a thread that the o2 sensor screws into. i forgot what it is called its cheap to make though and can be done at your local hardware store, someone will chime in soon
Old Nov 12, 2006 | 01:46 PM
R Legend's Avatar
IMO most sound the same and brand shouldn't be the deciding factor, after all it is just a section of straight pipe w/ 2 flanges. I have a cheap comptech replica w/ flanges that fit multiple size collectors. Been laying around the garage for months.
30 shipped and its yours. Has 2 o2 bungs welded in w/ covers.
Old Nov 12, 2006 | 02:01 PM
DontBlink's Avatar
Default Re: what TEST PIPE do you guys recommend (vtecjerry)
heres the cheap 02 simulator method. i didnt write this but its a really good step by step with pictures.
<FONT SIZE=""4"">
You now need to drill out 1 of the non foulers using a 1/2" drill bit. When finished this is what it will look like.
o2 Sensor inserted in the modified non fouler
Second, unmodified non fouler now installed on modified non fouler, then threaded into the downpipe
</FONT>
i used an electronic 02 sim from "zip tech" i bought it from http://www.importparts.com like 5 years ago. i cant seem to find it on their siite at the moment.
Old Nov 12, 2006 | 02:10 PM
rino924's Avatar
Community Builder
Default Re: what TEST PIPE do you guys recommend (DontBlink)
^^^^thats it
Old Nov 12, 2006 | 02:14 PM
MK Ultra's Avatar
How 'bout buying a cat with the appropriate flanges?
Do you really think 1-2 hp at best is worth spewing vastly more pollution into the air?
Old Nov 12, 2006 | 02:21 PM
vtec.dc2's Avatar
buy one of the latest carsound cats.. they're virtually unbreakable.. people run hundreds of hp with cats.. i'm certain you wo'nt know any difference running 160-170whp max
Old Nov 12, 2006 | 06:08 PM
cidgrad130's Avatar
Default Re: (MK Ultra)
to MK
Old Nov 12, 2006 | 06:14 PM
SkankyEJ7's Avatar
Default Re: what TEST PIPE do you guys recommend (rino924)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rino924 &raquo;</TD></TR><TR><TD CLASS="quote">1.) a quality test pipe is the T1R JDM length resonated test pipe
thats what i have, but it doesnt eliminate the buddy club spec2 rasp
Old Nov 12, 2006 | 06:15 PM
RagingAngel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MK Ultra &raquo;</TD></TR><TR><TD CLASS="quote">How 'bout buying a cat with the appropriate flanges?
Do you really think 1-2 hp at best is worth spewing vastly more pollution into the air? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cidgrad130 &raquo;</TD></TR><TR><TD CLASS="quote"> to MK</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">buy one of the latest carsound cats.. they're virtually unbreakable.. people run hundreds of hp with cats.. i'm certain you wo'nt know any difference running 160-170whp max</TD></TR></TABLE>
+1 and a WTFBBQX2.
But if you're on track, and looking to silence the exhaust a bit then the T1-R is a nice piece
Old Nov 12, 2006 | 06:17 PM
rino924's Avatar
Community Builder
Default Re: what TEST PIPE do you guys recommend (SkankyEJ7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkankyEJ7 &raquo;</TD></TR><TR><TD CLASS="quote">
thats what i have, but it doesnt eliminate the buddy club spec2 rasp</TD></TR></TABLE>
thats loud no matter what
Old Nov 12, 2006 | 09:48 PM
white rocket's Avatar
I'm running the T1R test pipe and its not raspy at all. However I will be putting my Vibrant high flow cat back on for next year when my car somes out of hiding since the difference in power isn't that noticable.
Old Nov 12, 2006 | 11:15 PM
98itRspec's Avatar
sorry to hijack thread. will the t1r exhaust fit w/ the usdm t1r exhuast fit into a usdm EM? and will it also fit jdm 4 1 header? thnx
Old Nov 12, 2006 | 11:30 PM
yeah i just want a simple install cuz i have stock exhaust but jdm header i have a skunk 2 on the way but ihead i need to have it modified since the piping is diffenent sizes and will need to be modified
Old Nov 12, 2006 | 11:31 PM
thanks for the pictures ive heard of this method before but when i ask how to do it ppl are unsure because they usually just pay to have shops deal with it
Old Nov 12, 2006 | 11:33 PM
but isnt the collector size different from JDM and USDM itr headers?
Old Nov 13, 2006 | 07:01 AM
DontBlink's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quickridez_3 &raquo;</TD></TR><TR><TD CLASS="quote">but isnt the collector size different from JDM and USDM itr headers? </TD></TR></TABLE>
USDM= 2" or 50.8mm USDM test pipe http://www.aj-racing.com/catal...age=2
JDM=2.5" or 63.5mm JDM test pipe http://www.aj-racing.com/catal...age=2
Modified by DontBlink at 11:39 AM 11/13/2006
Old Nov 13, 2006 | 10:23 AM
Mr.OB*GYN_Rhett's Avatar
ive always been interested in how a nice header and test pipe would sound on a stock R catback
Old Nov 13, 2006 | 12:29 PM
erikiksaz1's Avatar
Default Re: what TEST PIPE do you guys recommend (Mr.OB*GYN_Rhett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.OB*GYN_Rhett &raquo;</TD></TR><TR><TD CLASS="quote">ive always been interested in how a nice header and test pipe would sound on a stock R catback</TD></TR></TABLE>
I don't if you'd consider the jdm 4-1 a "nice" header, but coupled with a test pipe, it's not raspy at all. At WOT, the engine still drowns out the exhaust.
Old Nov 13, 2006 | 12:40 PM
Mike M's Avatar
Founding Member
Exactly..
Its not like your running FI where a Test pipe might net you a decent gain over a High Flow Cat, on the majority of NA setups (especially something as mild as your running) a test pipe only gives you 1-2whp at best over a good High Flow Cat like Carsound or IMCO
Old Nov 13, 2006 | 12:41 PM
Default Re: what TEST PIPE do you guys recommend (erikiksaz1)
i didnt ask if you were interested though did i. yeah id say it is a nice header, nothing crazy, but nice. i know in the cabin itll be quiet as stock, but behind the car.
Old Nov 13, 2006 | 01:29 PM
88 rex's Avatar
If you're running a stock header and stock exhaust then a straight pipe isn't worth the 1-2 hp IMO. A nice hi-flo will flow just fine and still function as a cat.
Old Nov 13, 2006 | 02:05 PM
crxgator's Avatar
Default Re: (88 rex)
even without the cat, our cars still make less pollutants than others that are stock...
im looking into the t1r jdm test pipe...that will bolt up to my usdm b pipe correct? im also thinking of getting the t1r bpipe next year, that should bolt up to my itr muffler?
Old Nov 13, 2006 | 02:59 PM
rust_free_civic's Avatar
Omni power has what you need. 2.5 " collector, o2 bung, ajustable length and cocking for about 100 bucks. I have one on my type r swap and it bolts right up to the cat back.
Old Nov 13, 2006 | 04:08 PM
88 rex's Avatar
Default Re: (crxgator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">even without the cat, our cars still make less pollutants than others that are stock...
im looking into the t1r jdm test pipe...that will bolt up to my usdm b pipe correct? im also thinking of getting the t1r bpipe next year, that should bolt up to my itr muffler?</TD></TR></TABLE>
I failed with a bad cat and passed with a good cat. Bad cat = no cat.
Which cars do our cars make less polutants than without the cat on our cars? I've never sat behind any stock, decent running cars and smelled exhaust fumes excluding diesel.
