How to put in a fuel presure regulator
Old Nov 12, 2006 | 01:13 PM
Rex89's Avatar
Default How to put in a fuel presure regulator
i just got my fadujustable fuel presure regulator anyone one no how to intall it and how to calibrate it right so i can get the full potetial out of it in the rex si
Old Nov 12, 2006 | 01:58 PM
eda6's Avatar
Default Re: How to put in a fuel presure regulator (Rex89)
first install a gage on the fuel filter. remove the vacuum hose from the fpr, turn the car on and write down the fuel pressure.
what fpr are you installing? pretty simple two bolts and an o-ring. then check for leaks and set fuel pressure.
Old Nov 15, 2006 | 01:26 PM
Rex89's Avatar
Default Re: How to put in a fuel presure regulator (eda6)
the fpr has a gauge already on it theres 3 connections one at the bootom one to the right and a smaller hose on top but i dont no were to hook up what
Old Nov 15, 2006 | 01:36 PM
RCautoworks's Avatar
If you are asking how to install it, may I ask who is going to adjust it for you ? Unless you are going to adjust in spec to the manual, I would not touch it.
Old Nov 15, 2006 | 01:39 PM
BiG Chris's Avatar
got a picture of the one you are installing?
Ej8_KiD
Engine Management and Tuning
Oct 30, 2009 06:31 PM
sikkcrx
Mar 19, 2007 05:47 AM
vietdragontekx
Feb 12, 2006 06:22 AM
Mr. Roboto
Jan 24, 2005 05:08 AM
redman223
Jan 16, 2004 05:28 PM
