Will S2000 seats bolt right in?
Old May 7, 2002 | 06:17 PM
2K_TEG's Avatar
Default Will S2000 seats bolt right in?
If not, what do you need? Thanks
Old May 7, 2002 | 06:26 PM
Mike B's Avatar
Default Re: Will S2000 seats bolt right in? (2K_TEG)
Need a drill and a few heavy duty bolts/washers.
The front 2 brackets are flattened out because (I think) they mount horizontally on the surface of the s2000 floorboard. You just have to get a mallet and pound the bracket at an angle. When I say pound, one hit will probably do it. The back inner bracket lined up perfectly to the floorboard. Drill and bolt. The outside bracket required a little creativity but came out just fine.
Here is my car.
Old May 7, 2002 | 06:38 PM
ebelp's Avatar
Default Re: Will S2000 seats bolt right in? (Crazy Bovine)
I wonder if RSX seats would fit in an Integra...those seats are very very nice.
Old May 7, 2002 | 06:43 PM
Mike B's Avatar
Default Re: Will S2000 seats bolt right in? (ebelp)
My friend has a TTSupra and mounted the RSX seats in there. Those look very NICE however, they sit EXTREMELY too high for the DC2 chassis. We were just foolin around and see how they fitted. We customized the bracket and made a few additions of our own, and it STILL sat too high.
Problem I found with the RSX seats is because they are ride height adjustable. They have that little **** on the side where it tilts the seat. There is ultimately no convenient way in mounting them correctly.
My friend has a 2002 EX Civic EX Coupe. Fits like a glove in the later style vehicles.
Old May 7, 2002 | 07:16 PM
Mike B's Avatar
Here is a lager pic.
Old May 7, 2002 | 07:17 PM
2K_TEG's Avatar
Here is my car.
Do you have any bigger/different pics? I would like to see. How much do they go for? TIA.
Old May 7, 2002 | 07:18 PM
2K_TEG's Avatar
you beat me to it!
Old May 7, 2002 | 10:33 PM
TKBLAZER's Avatar
why couldn't honda make those seats stock....i would love to have oem s2000 seats in my teg...but i dont like the thought of drilling into the floor board like that
Old May 7, 2002 | 10:58 PM
Rhetoric's Avatar
Default Re: Will S2000 seats bolt right in? (TKBLAZER)
Are S2k seats pretty heavy? Do they weigh more than gsr leather or itr's?
Old May 7, 2002 | 11:29 PM
Mike B's Avatar
Default Re: Will S2000 seats bolt right in? (G S R)
Lighter than GSR's for sure.
Old May 7, 2002 | 11:32 PM
Mike B's Avatar
Its not as bad as it sounds. I put steel plates on both sides.
Old May 8, 2002 | 12:07 PM
bhcvc's Avatar
Do the S2K seats recline all the way back? Just curious to know if they retain the full range of motion as the factory seats. Thanks.
Old May 8, 2002 | 12:23 PM
owen_the_soyboy's Avatar
no way man, test that setup in an accident.. not with my life. try to find another way to modify those brackets please
Old May 9, 2002 | 12:25 AM
Mike B's Avatar
Default Re: Will S2000 seats bolt right in? (bhcvc)
They dont recline any further than a 45 deg angle.
Old May 12, 2002 | 08:19 AM
TrendsetterEllis's Avatar
All you have to do to S2000 seats is bend the rails in the front as mentioned in this post. One rear bolt will bolt up in a 96-01 Civic. A total of 3 bolts will line up for a Civic. However for an Integra, the rears do not line up, but the front 2 are sufficient, because the S2000 seats sit very low and are extremely sporty. I have them in my Integra, and the seats dont rock back and forth , and are very stable, unless I go over some crazy *** potholes.
The S2000 seats are significantly lighter as well!
[Modified by TrendsetterEllis, 5:20 PM 5/12/2002]
dc2ls-vtec
Aug 16, 2008 04:24 PM
thatwhiteguy
Jul 15, 2007 08:26 PM
UNBRE4K4BLE
Nov 18, 2005 09:24 PM
wako182774
Sep 4, 2005 05:52 AM
BlackThorN
Sep 2, 2003 08:57 PM
