integra rack n pinion into eg,,, need some help
Old Nov 12, 2006 | 10:28 AM
carlosd68's Avatar
Default integra rack n pinion into eg,,, need some help
i searched and saw it bolted up, but wat do i do with the power steering lines?,,,also is there a bracket that doesnt fit? ..ima start working on this in a couple hours so any help is appreciated
Old Nov 12, 2006 | 12:19 PM
Dwight Schrute's Avatar
Default Re: integra rack n pinion into eg,,, need some help (carlosd68)
you have bend them to fit, also need to block block off the third civic line. i just blocked it off at the ps resevoir with a rubber nipple. you need the u joint where the rack connects to the column for the integra otherwise it wont work.
MuPhukinxP
Apr 3, 2019 09:29 AM
SpeedRacerEX-R
Suspension & Brakes
Jun 6, 2016 03:39 PM
mattbatson
15
Feb 20, 2010 05:40 AM
drift2004
Suspension & Brakes
Oct 6, 2008 09:15 PM
