Bogarts & lugs?
Just purchased a set of bogarts & they have a flat faced bolt pattern, my ? is what lugs are you guys using, seeing how most rims are tapered & so are the lugs???
i used a shanked style lug with washer this year, but i found something cool.
I found a package from weld that had 5 adapters to make a shanked lug wheel into an acorn style wheel. its just an insert that goes into the wheel.
The only problem is that weld no longer produces this part nor has any information on them. I may go to my local CNC guy and have him cut some for me this offseason. this would allow the use of a lighter lug with bogarts.
-Francisco
-Francisco
i have those inserts for my welds. Francisco if you want to borrow one to use to take to the machine shop let me know. i can let you borrow one or a few
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 »</TD></TR><TR><TD CLASS="quote">i have those inserts for my welds. Francisco if you want to borrow one to use to take to the machine shop let me know. i can let you borrow one or a few</TD></TR></TABLE>
thanks brett. i got a set of 5 actually. I'll probably send a couple out to different shops and see who can make a run of 100-200 for the best price.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reaction360 »</TD></TR><TR><TD CLASS="quote">i used a cragar style mag wheel lug with washers and cut the ends off for my extended studs.</TD></TR></TABLE>
you cut the rounded end off? i was thinking of doing this but figured id get **** for it from tech.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteczone »</TD></TR><TR><TD CLASS="quote">with all the explanation on the lugs..does anyone have pix of those lugs? my english is just as bad as my knowledge on non honda car..
Bump for pics. I just picked up some bogart skinnies and I need lugs.
</TD></TR></TABLE>Bump for pics. I just picked up some bogart skinnies and I need lugs.
Drag wheels are drilled like that so you can run shank lugs. They are stronger and safer than tapered lugs. The shank supports the wheel stud and keeps the studs from deflecting under a hard launch. Look for them in Summit or Jegs. You'll see a picture of them.
(haven't been trying to argue, just trying to give/find info about all this)
what all can happen bad from the lug issue? is it just breaking or bending the stud from the lack of support or what?
All the torque is applied through the stud to the wheel. Have you seen the contact area on those weld adaptors? It's just a safer more secure way to do it with the shouldered lug. I'd imagine it's better for the wheels and the studs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RPRacing »</TD></TR><TR><TD CLASS="quote">what all can happen bad from the lug issue? is it just breaking or bending the stud from the lack of support or what?</TD></TR></TABLE>
When you lose your front wheel and crash into the guardwall, you might have to replace some things.
and when a motor blows up you have to replace some things. i dont see how your response answers anything. obviously the lug nut holds the wheel on. my question was what exactly could happen from improper lugs. would they not hold a torque, would they snap a lug, twist a lug, etc.
tony, thanks for the response
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RPRacing »</TD></TR><TR><TD CLASS="quote">and when a motor blows up you have to replace some things. i dont see how your response answers anything. obviously the lug nut holds the wheel on. my question was what exactly could happen from improper lugs. would they not hold a torque, would they snap a lug, twist a lug, etc.
tony, thanks for the response</TD></TR></TABLE>
It's called sarcasm.
Let me dumb it down some more.
The stud is unsupported inside the wheel. It bends every time you launch. One of those times you lose a wheel. Then, bad things happen. Maybe even real bad things. Sorry my Japanese isn't so good.
Let me dumb it down some more.The stud is unsupported inside the wheel. It bends every time you launch. One of those times you lose a wheel. Then, bad things happen. Maybe even real bad things. Sorry my Japanese isn't so good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RPRacing »</TD></TR><TR><TD CLASS="quote">thanks for being a smart ***. was there a reason you had to present your information like a jack ***?</TD></TR></TABLE>
I guess I assumed you had a sense of humor. I didn't realize you tampon was leaking. Sorry.
