tire size for 5th gen prelude?
Old May 7, 2002 | 05:46 PM
sab_showlude's Avatar
Default tire size for 5th gen prelude?
I was planning on purchasing some rims with 225/40/18s, will these tire size be good on a dropped 5th gen prelude? any suggestions on what I should get?
Should i be stickin wit 215/35 or 215/40?
Old May 7, 2002 | 07:06 PM
tonydatyga's Avatar
Default Re: tire size for 5th gen prelude? (sab_showlude)
40
Old May 7, 2002 | 07:54 PM
Default Re: tire size for 5th gen prelude? (tonydatyga)
Bump, please offer more suggestions, I really want to know what I should be gettin for my $$$. Dont wanna waste 2g and be dissatisfied
Old May 8, 2002 | 04:48 AM
Anubyss's Avatar
215/40 would be good. The offset should be 45+.
Old May 9, 2002 | 04:36 PM
Buckwild's Avatar
I would go with 225/35's. That'll keep you closer to stock tire diameter. If you get 225/40s, you'll probably notice it affecting ur speedo alot more.
If you want, 215/40's will work as well.
Here's the formula so you can calculate tire diameter:
(width of tire)/25.4 = A
A * (aspect ratio) = B
B * (2) + (rim diameter) = C
C = overall diameter
Hope this helps...
Jon
Old May 9, 2002 | 10:24 PM
Volk Girl's Avatar
Default Re: tire size for 5th gen prelude? (Buckwild)
If you ever look at a lude wit 215 and a lude wit 225, I think the 225's look hell phat. It also handles at turns better. Any offset over 45 is ok to drop without rubbing. The higher the offset the more you can drop it. If you get 35 series tires then you just have to be more careful about bending the rims if you hit potholes and those stupid metal plates they always have out in the middle of the roads. 40 series will give you a little more support.
Old May 10, 2002 | 03:01 PM
JG Luder's Avatar
Default Re: tire size for 5th gen prelude? (SweetGurlRacer)
You hit a pothole with 35's and you can kiss those 18's goodbye.
35's:
Show = great
Street = ***
RA102725
Aug 24, 2006 10:17 AM
'01silveri'sh'
Mar 21, 2004 08:59 PM
hOndafienD 04
Jan 18, 2004 08:57 AM
nicksweetlude
Dec 10, 2001 07:26 AM
