vtec pressure switch VTP code 22
Old Nov 12, 2006 | 01:23 AM
hondaman156's Avatar
Default vtec pressure switch VTP code 22
wires are going to the correct pins. and we got code 22 (VTP)
manual says the sensor should read 18 to 30 ohms? from harness to ground read 3.4 ohms. does this mean a bad sensor????
its also reading code 20 (ELD) could this be related.
total codes reading:
14-IACV
20-ELD(elec. load detector)
22-VTP(vtec pressure switch)
WHAT ELSE SHOULD WE CHECK???
ANY HELP???
Old Nov 12, 2006 | 03:49 AM
Duane_in_Japan's Avatar
Default Re: vtec pressure switch VTP code 22 (hondaman156)
Clear the codes and see which ones come back, immediately or after a day or two of driving, keep checking for codes then let us know. Dont start pulling sensor wires setting your own codes. Also do a search all over H-T, VTEC codes are all over the place, make damn sure your oil level is FULL.
Old Nov 12, 2006 | 06:11 PM
Default Re: vtec pressure switch VTP code 22 (Duane_in_Japan)
i swaped a 93 d16z6 long block into my 99 dx and am reading these codes im lost any help would be great
LS Turbo300
Feb 27, 2014 04:50 AM
LS Turbo300
Aug 23, 2012 04:47 AM
brandynEG
Jun 28, 2012 06:23 PM
vtec93accord
Nov 3, 2003 08:09 PM
89Civic
Jun 10, 2002 12:16 PM
