Help me start my Civic----> identify these plugs......... Plz!!
Hey guys, well I need help hot wiring and starting my civic.
My ignition switch was cut out from underneath and some stuff was stolen from my 96 civic EK coupe.
Could someone help me move this car.
I tried splicing all these wires together
12v constant- white
assesory- yellow
ignition- blk/wht
???-wht/ blk
and then touch the starter to power to start the car. It just cranks but no-start.
could you aslo take a look at these pictures and tell me whats wrong.
In this pick could you tell me what relays plug into #1. And where do the plugs for #2, and #3 go.
For this pick could you tell me
What device/box plugs into #1
what relay plugs into #2
What device/box is #3
Thanks for any and all you guys help.
12v constant- white
assesory- yellow
ignition- blk/wht
???-wht/ blk
Ok let me try to help you out.
First pic:
1. Cant really tell but there are some plugs like that behind the fuse box, check there and see if one might fit.
2. Looks to just be relays right? Are they still plugged up and such? no cut wires? If so i think you could zip tie them together and run tuck them way to hard to really see what there for.
3. Same as 1.
2nd Pic:
1. OBD scanner plugs into there.
2. Thats the power window relay
3. There shouldnt be any circuit board exposed like that. Check behind the fuse box if it might have came from there.
First pic:
3. Same as 1.
2nd Pic:
thanks
1) those where just hanging there, i put relays in them, those were just some regular relays.
2) same thing.! and 3!
on pic 2
can i use any obd1 sccaner eevn from an integra.
3) that seams to be a power window box without the metal casing??
on pic 2
bottlefedb17
Honda Civic (2001 - 2005)
Oct 9, 2008 12:06 PM
fabe85
Nov 11, 2006 05:41 PM
fabe85
Nov 11, 2006 05:39 PM
