Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
race oil for a b18 integra?
Old Nov 11, 2006 | 04:28 PM
fonzy's Avatar
Default race oil for a b18 integra?
im getting my integra ready for ice racing duties, and being i am new at this honda stuff, what do you guys use? i have used both amzoil and redline in my old vw's and fiats ,? should i go with one of those? also i heard that mtl from redline is a bad choice for honda trans, is this true?
thanks
Modified by fonzy at 6:30 PM 11/11/2006
Old Nov 12, 2006 | 01:44 AM
chrisw85's Avatar
I've used Redline MTL in my 94 civic ex's transmission, and I liked the performance and shift feel better with Amsoil 5w30 MTF, the amsoil is just that much better than MTL to me.
As far as engine oil, you coul go with 5w30 Mobil 1 synthetic, it has a pretty good cold pour point, otherwise if you need better cold pour point/flow then go with Castrol 0w30 (german castrol), or possibly 0w40 Mobil 1.
If you have access to Esso, get the esso xd-3 0w30 or 0w40; they're great values for a great performing oil. I've only seen it in Canada so far.
Old Nov 12, 2006 | 11:27 AM
Weston's Avatar
Redline MTL is great for the transmission, but maybe not in cold conditions. In warm/hot conditions, it easily kicks Honda MTF's ***.
As for the engine, I like Valvolene SynPower. Mobil 1 tends to disappear.
Old Nov 12, 2006 | 11:38 AM
pos_cd5's Avatar
Default Re: (chrisw85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 &raquo;</TD></TR><TR><TD CLASS="quote">
If you have access to Esso, get the esso xd-3 0w30 or 0w40; they're great values for a great performing oil. I've only seen it in Canada so far.</TD></TR></TABLE>
if i remember correctly i remember seeing a ad in superstreet saying that esso is now avaible in the US. what do you guys think of GReddys line of high-performance oils?
Old Nov 12, 2006 | 01:03 PM
fonzy's Avatar
Default Re: (Weston)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Weston &raquo;</TD></TR><TR><TD CLASS="quote">Redline MTL is great for the transmission, but maybe not in cold conditions. In warm/hot conditions, it easily kicks Honda MTF's ***.
As for the engine, I like Valvolene SynPower. Mobil 1 tends to disappear.</TD></TR></TABLE>
i was reading on the honda challege forums that they all like the honda mtl stuff, they say the mtl hurts sycros
Old Nov 12, 2006 | 05:56 PM
cidgrad130's Avatar
Default Re: race oil for a b18 integra? (fonzy)
I used Redline motor oil in my dedicated Prelude Track car...never in the kind of cold conditions that you are likely to experience though. If you go with Redline...I would not use the Race oil (single viscocity)...I would use their line of synthetic dual viscocity oil.
Cheers!
Old Nov 12, 2006 | 10:22 PM
Weston's Avatar
Default Re: (fonzy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fonzy &raquo;</TD></TR><TR><TD CLASS="quote">i was reading on the honda challege forums that they all like the honda mtl stuff, they say the mtl hurts sycros</TD></TR></TABLE>
In my experience, Redline MTL clearly prolonged the life of my synchros. I had a slight 3rd gear crunch with Honda MTF, which was disappointing because I had replaced that synchro only about a year earlier. I then switched to Redline MTL and the crunch went away completely and didn't come back until a year and a half later when I abused that synchro pretty bad (clutch disc lost a spring which got jammed in the pressure plate, and I was in a bad situation where I really needed it to go into gear, so I was grinding the hell out of it). I've only heard of issues with Redline tranny fluid when the weather was cold (although this seemed to be mostly speculation), or when people were using the wrong weight of it (for most Hondas, you want the one that's actually called "MTL").
Old Nov 13, 2006 | 05:40 AM
fonzy's Avatar
In my experience, Redline MTL clearly prolonged the life of my synchros. I had a slight 3rd gear crunch with Honda MTF, which was disappointing because I had replaced that synchro only about a year earlier. I then switched to Redline MTL and the crunch went away completely and didn't come back until a year and a half later when I abused that synchro pretty bad (clutch disc lost a spring which got jammed in the pressure plate, and I was in a bad situation where I really needed it to go into gear, so I was grinding the hell out of it). I've only heard of issues with Redline tranny fluid when the weather was cold (although this seemed to be mostly speculation), or when people were using the wrong weight of it (for most Hondas, you want the one that's actually called "MTL").</TD></TR></TABLE>
well i will be using it in the cold , so maybe not the way to go for me
Old Nov 14, 2006 | 09:42 AM
dvp's Avatar
dvp
Default Re: (fonzy)
Amsoil or Honda fluid should be fine for the tranny in the cooler weather. Amsoil or Mobile one for the motor.
genman217
Jul 13, 2014 06:05 PM
unusual71
Transmission & Drivetrain
Nov 27, 2010 09:27 AM
Mashka
Honda S2000
Sep 3, 2007 01:50 PM
dochmees
Nov 30, 2002 11:58 AM
citanest
Oct 17, 2001 09:50 PM
